Hi All, Just finished to install my new rig and I have few problems.
I tried to connect the Freezer 7 Pro to the CPU fan on the GA-P35-DS3L and at the beginning it started to spin for few seconds and than stopped after few more seconds it started again and again stopped. So I decided to connect the fan to the other 4 pin fan socket (which is labeled as PWM fan). Over there it works without a problem. I tried the original intel fan on the CPU fan without any success. Do you think that I might have a defective motherboard or maybe something that I'm missing in the configuration. I would like to connect the Freezer 7 Pro to the CPU fan socket as I think it there should be some control capacities on the motherboard.
Any help is welcome.
Thanks,
Yossi
Thanks,
Yossi
