Hi Guys,
Planning to build a new computer around the end of Dec to replace my current 4 year old computer. I'm actually from Australia so my links will be from vendors over here.
Currently I'm looking at:
CPU:
Intel E6750 Core 2 Duo
http://www.itestate.com.au/products_detail.asp?code=PD00004891
Mobo:
Intel BLKDP35DPM, INTEL P35/LGA775/ATX/1333FSB/G-LAN/PCIe X16/AUDIO/RAID
http://www.penta.com.au/template.php?seqid=13484
RAM:
Corsair-Performance 2GB (2x1024) 800MHz XMS2 TWINX2 MATCHED (TWIN2X2048-6400) 5-5-5-15
http://www.itestate.com.au/products_detail.asp?code=PD00004095
or
Desktop DDR2 Ram 2GB Kit (2x1024MB) PC6400 800MHz Geil Ultra 4-4-4-12
http://www.itestate.com.au/products_detail.asp?code=PD00004475
(I don't know much about rams and there aren't as many brands to choose from over here, so please help me decide)
Video Card:
Leadtek Winfast PX8800GT PCI-E 2.0 512MB 256-bit GDDR3, 600/1800MHz
http://www.onlinevip.com.au/product_info.php?products_id=2905&osCsid=8cc19f508b96435c57e76a954a94a404
HD:
WD WD3200AAKS WD 320G 16MB 7200 SATA2 3.5"
(I've already bought this 2 months ago because my old maxtor play dead on me, so I hope it won't be much of a problem if I just plug this HD into my new rig)
Case & PSU:
ANTEC Sonata 3 (III) Black with Antec EarthWatts 500w PSU
http://www.itestate.com.au/products_detail.asp?code=PD00004873
(Running on a low budget so this is probably the only case that comes with a decent PSU within my budget)
Sound Card:
Sound Blaster Audigy Value
(Do I really need one or the one on the intel board is sufficient?)
Optical Drive:
Pioneer DVR-115DBK 20x IDE
(This is the drive I'm currently using, hoping to salvage this to save myself $30 )
I'm currently using an ASUS VW222U 22" monitor and hoping that this new rig will be enough to run games smoothly in 1650x1050 for at lease a year or two. Please give any suggestions if I can improve this build any further without overclocking or putting in anymore money as this is already the most I can spend.
Thanks Guys!!!
CPU:
Mobo:
RAM:
or
Video Card:
HD:
Case & PSU:
Sound Card:
Optical Drive:
Thanks Guys!!!
