Tom's Hardware > Forum > Motherboards & Memory > Asus > dual channel freezing problem on Asus P5NT WS
Forum Motherboards & Memory : Asus - dual channel freezing problem on Asus P5NT WS
Hi there,
I currently have freezing problems whenever i place my 2x1024 Corsair TWIN2X2048-6400C4 in dual channel on the Asus P5NT WS. It tends to freeze a 1 min or 2 after i log into windows. Atm both rams are on single channel and there are no problems of freezing and have left my computer running for a week, problem only occurs with dual channel and i really want to use dual channel for the performance.
My Specs:
Intel Q6600 g0
Asus P5NT WS
2 gigs Corsair TWIN2X2048-6400C4
galaxy 8800gts 512 mb g92 sli
Antec p182
Silverstone 650 watts zf psu
Note: i have not OC anything in my specs
Any help would be great!
Sponsored Links
I have the same problem with my Asus P5N32E SLI Plus. Both sticks work fine in Single Channel mode but freeze after 10mins in dual channel. Have tweaked the voltages and no difference other than making it unpostable. Tried with two sets of mem:
OcUK 2GB (2x1GB) DDR2 PC2-8500C5 1066MHz Dual Channel Kit
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2
Already RMA'd the motherboard but it was returned as working fine, BIOS updated to 0901 version.
Total pain in the arse.
Reply to BlackIsle
- 0 +
Check the voltage in the BIOS and make sure it's the same as the RAM
Reply to g-paw
If it was the voltage, why do the same two sticks run in single channel mode?
(and the voltage is correct)
Reply to BlackIsle
- 0 +
There is an outside chance one could run but not 2. Didn't know if the OP checked. Always possible a bad mobo.
Reply to g-paw
that's what I thought at first and RMA'd the mobo but the supplier has tested it and reckons it's fine :(
The exact OCZ memory isn't on the QVL but is running fine at 400@5-5-5-15 2T
Everything is at stock/SPD speeds
QVL = OCZ2T8002GK
Fitted= OCZ2P800R21G
3DMark scoring 12000, PCmark scoring 8000, memtest passed repeatedly in single channel mode :(
Reply to BlackIsle
- 0 +
It really sounds like a BIOS setting if the mobo tested out and you've tried different RAM. I'd do the following. Clear the CMOS, next Flash to the most recent rev of the BIOS even if that's what you already have, and if all else fails, try different BIOS settings but this would be trial and error.
Reply to g-paw
i pasted this from another post if your not running sli get an intel mobo
tyz wrote :
i,ve had one of these a week now nothing but trouble. BSOD 0x0000124 and or freezing up as soon as it gets to the windows enviroiment on Vista 32 bit . Put XP on it little better but as soon as you ask it for some load freeze up's BSOD . Installed call of duty 4 never got to play it, error every time tryed to start programe. Nvidia chipset on the board not any good need wait till Asus fixes it...
the reason is:
1) nvidia mobo's suck!
2) asus really does no make good 680 mobos so the 780 is the same - i use mostly asus mobos
3) you have not tuned the system right - nvidia mobo's are really sensitive to voltage and memroy settings
if you can not tune it and you have only one card - sell it too me or trade for x38 or p35
for example - it can take 3 hours to tune a 680i mobo to 3.3ghz with q6600 b3
it takes 3 mins to get every intel mobo to 3.6ghz with both p35 and x38 mobo
increase your memory and cpu voltage
------------------------------ http://i63.photobucket.com/albums/h138/4rothrocks/WarpedSystemsAnimation-1.jpg
Reply to dragonsprayer
There are 535 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
