Hi, i just bough my new computer and iv'e try to set the memory to is maximum clock speed but the CPU gone crazy. CPU go up to 90 Celsius. Even if i try to set at 800 MHZ to CPU overheat. I didn't try to over clock the cpu because i don't need it.
My cpu spec are
P5N32-E SLI (680i), Intel Core 2 Quad Extreme QX6850 3.0Ghz, 4G Ram OCZ Reaper Kit PC-9200 1150 MHZ, GeForce 8 eVGA 8800 Ultra, SoundBlaster X-FI Fatality Pro Gamer, 750G Western Digital 7200RPM.
By default the memory is clock at 667Mhz. I put the FSB at the same speed with the memory and iv'e check the timing and voltage with OCZ and everything is ok. My BIOS current version is 1103.
What should i do??
P.S. Just wanna say that i never overclock before so i am not familiar with those kind of problems.
My FSB is at 1333Mhz stock so i put it at 1150Mhz. What should i do if I want to put my memory at 1150Mhz or 800Mhz?? What should i do? What should be the ratio?? Now i put the memory manager at Automatique so my Mobo put the memory speed at 667MHZ so it little bit slow. If you need more information just ask for it.
when it's unlinked you can just type in 1150Mhz
in overvolting set your ram voltage to 2.2v or whatever it is rated at
My other computer (with same mobo as yours) is tied up, so later on I'll go through and look at the bios again so I can tell you what screens... In the meantime, maybe someone else has some screen shots for you.
------------------------------P5N32-E-SLI, e4300@3.2, 4x1gig tracers 1:1 , 8800gts-320 OC ?/?, antec 850w psu, antec 900 case
Vista64 Ultimate
Reply to davelakecity
Unlinking works and all, but I'd be more worried about the temps. Assuming it's not a faulty sensor, make sure the cooler is seated correctly and that you have the right amount of paste. 65C for core temps are the max safe temps for that extreme cpu.
------------------------------"Nvidia, the Way It's Meant to be PAID Played! - Corrado
*Lesbian Lover Club* - founder Assman
Reply to Evilonigiri
