Tom's Hardware > Forum > Graphic & Displays > Nvidia > 8800GT Power Connector
Ok so i got my 8800GT today, and it came with this power cable that i am not sure if i should use. Here is what it looks like:
http://images10.newegg.com/NeweggI [...] 205-09.jpg
My power supply has a pcie power connector, should i use that instead of the extension provided with the card? I`m guessing it was included in case the power supply didn't have a pcie power connector?
Thanks for reading :).
Sponsored Links
Yes use the Pcie connector if your PSU has one. Your guess is correct, it is included in case your psu does not have a pcie connector.
------------------------------ 3 more years to get my BSEE @ UNH :(
Intel E2200 @ 2.90Ghz (264x11) | 3GB DDR2 800 G.Skill (2x1GB, 2x512MB) | Gigabyte DS3L | Gigabyte 8800GT 512 @ 675/1566/900 | 160GB Seagate 7200rpm SATAII | Seasonic 500Watt SS-500ES | XP Pro
Reply to soloman02
Hey thanks for the fast reply mate, didn't think anyone would reply at this time.
:bounce:
Something on a side note, why exactly do you need to use the dongle to plug the monitor to the graphic card? Couldn't they build the graphic card with the connector for an LCD right into the card, or was it made like this to connect some other display?
Thanks.
Edit: Formatted my pc and am installing drivers atm, and noticed in speedfan that this card (unlike my old 7900 gt) has a temperature reading called "Ambient". What exactly is this? Is it the air around the card?
And are these readings any good? (these where taken at idle)
Core: 55
Ambient: 43
Message edited by thegatekeeper on 12-20-2007 at 12:23:37 PM
Reply to thegatekeeper
There are 1161 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
