Asus 780i
Q6600 Core 2 Quad 2.4
evga 8800Gt
G. Skill 2gbx4 DDR2 1000
Raptor HDD
Tagen 900w PSU
Tower 120 cpu cooler
6 x 120mm scythe 110cfm fans
cooler master cosmos 1000 case
Win Vista x64 / XP pro sp2
Put it all together, got it up and running installed Vista x64
computer ran for 15mins or so with vista just fine, so I started installing my drivers to put in the rest of my ram in and add my second 8800Gt. Installed Asus Mobo Drivers and ..... Hard lock, ok what the heck, reboot....get the windows load screen, and locks again, deleted/create partition and re-formatted. Install Vista once more, gets through the install reboots to run windows for the first time, and hard locks at the load screen, Tried different hard drive, ram, & video card. Every time, installs just fine, and hard locks on windows load screen. I figured maybe it was just Vista, so delete the partition, recreate and format, then install XP Pro Sp2, install's just fine. Windows load screen and hard lock. I'm thinking its the chipset in the motherboard.
If it had not installed and been up and running it would make more sense, but i'm thinking its either the chipset or the cpu, according to bios the Q6600 is sitting at 38c so no problem there, no post error. Thinking about trying to RMA the mobo, IF i can get the bottem bracket off the this board.
Any suggestions?
evga 8800Gt
Raptor HDD
Tagen 900w PSU
Any suggestions?
