Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > ATX cable extenders question
Forum Homebuilt Systems : General Homebuilt - ATX cable extenders question
My cords dont reach. I need the 4 pin as well as the 24 pin, my question is this
Newegg seems to be where I will order it since no stores carry it. My power supply has 24 pins, and my mobo has 24 pins but all I can seem to find is 20 pin to 24 pin and 24 pin to 20 pin.
Is it ok to just grab one of these? Or do I need to find a 24 pin to 24 pin?
Also, there are no washers between the standoffs and the mobo, some say that is fine and it wont short, but I want to double-check.
Message edited by alzarius on 12-14-2007 at 05:43:51 PM
Sponsored Links
Some boards with 24 pin can be run just fine with a 20 pin. I'm not sure what your board is or if it would safely run w/o the extra 4 pin, but it's something you may want to check out.
Quote :
Mine didn't come with any washers and I have no problems at all (nor did the case before my current one).
Message edited by rgeist554 on 12-14-2007 at 06:36:26 PM
Reply to rgeist554
Gigabyte GA-P35-DS3L is what I have
They are impossible to find in stores so I was going to order one but didnt see any 24p to 24p that could be ordered. I was thinking about just getting another atx extender but not sure if the voltage and everything would be the same so didnt do it and just looking to see if I can plug my 24 from the psu to the 20 (even though it holds 24) in the mobo
Reply to alzarius
Here is a 12-inch 24-pin ATX cable
http://www.performance-pcs.com/cat [...] ts_id=2512
and a 4-pin
http://www.performance-pcs.com/cat [...] ts_id=4640
They also offer the 6-inch ATX extension.
Reply to cookin
Thanks!
I cant find the 24 pin atx extension on newegg (about 20 bucks cheaper if i coudl find it) so I may end up ordering it from there
Reply to alzarius
They could make it easier to find. I just had to find one recently so I knew where to look.
Reply to rook
There are 838 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
