I decided to build a new system, for the normal reason; my old one just wasnt cutting it.
shoped around bought the parts. got em shipped and put together.
that was yesterday...
on the first boot things went swimmingly!
the mb recognized the video card the cpu and the ram all properly.
all tempratures were normal (~32c cpu and case)
so then i went into the BIOS (manual in hand) to look through settings.
about... ohh... 20 minutes later i was exiting out of a sub-menu of the BIOS
(pressing the esc key) and poof! the computer just goes silent. (aka no power)
and now it wont turn on.
occasionaly when i push the power button, the lights in the room dim momentarily,
(as they did on the first boot) and i here a Bzzzt noize coming from the powersupply,
(the sound lasted about as long as it takes to read the word) and then nothing.
The fan on the video card tries to spin up when the power button is pushed, but as
far as i can tell none of the others do.
I tested the Powersupply on an older system (20 pin atx as opposed to the 24 +4 pin
on the new bord) and it seems to work fine.
my new system specs are:
CASE: CM STACKER NO PS BK STC-T01-UWK (I know ppl said this case was huge...ginormous is mor like it)
PS: Rosewill RX850-D-B ATX12V v2.2 & EPS12V v2.91 850W
MB: MSI AM2+ AMD 790X 2PCIE K9A2CF-F ATX
CPU: AMD Athlon 64 X2 6000+ Windsor 3.0GHz Socket AM2 Dual-Core Processor Model ADX6000CZBOX
GPU: SAPPHIRE 100215L Radeon HD 3870 512MB 256-bit GDDR4 PCI Express 2.0 HDCP
RAM 2gb Kingston ram
I have not plugged anything else in yet
Havent tried anything else yet but i will tonight and this weekend, any suggestions and/or solutions
would be much appreceated.
thanks
thanks
