Ok for all you people with gigabyte mobo who have the problem of booting up for 3 seconds then shutting down and repeating itself. The problem is from the CPU LATCH/ CPU SOCKET.
This is were i need help:
WHen i close the latch and lock the cpu it runs for 3 sec or so and shuts down but when i leave it UNLOCK then it works. How do i fix the latch door so I can lock it and make it work.
Just closing it without locking it the latch/door has a slight angle going upwards. so its flat on the bottom and going upwards toward the yellow arrow on the cpu. Is it suppose to be like that or is it suppose to be flat and flush to the cpu when you close the latch but without locking it yet.
Thanks in advance to all that helps!!
