I just switched to a new motherboard a Gigabyte GA-P35-DS3L(Bios Version F5) from a 775Dual-VSTA and since then my 4300 temps during load peek around 60-65c under full load with orthos. This is with a clock setting anywhere from 2.4-3.0Ghz.
I've tried resetting the heat sink three times but end up with the same result. My idle temps are between 33-35. My idle temps where the same with the 775Dual but load (limited to 2.7) never broke 50c. This is with a Cooler Master Hyper TX2 heat sink.
I am using Artic Silver ceramique. My case is a Cooler Master Cavalier 3(CPU duct is removed and a 80mm fan is in its place, also replaced rear 120 with a 62cfm fan)
Temps where taken with Core Temp .95
Any suggestions?
Any suggestions?
