Remote connection
Hello,
my remote connection disappears as soon as i hit connect. Never had a problem connecting until recently. Any ideas?
1 answer Last reply
More about remote connection
  1. rstanfill said:
    Hello,
    try using system restore to set the computer back to a date before the problem started.
    click start, click all programs, click accessories, click system tools, click system restore, check box: restore my system to an earlier time, click next, select a bold date on the calender before the problem started, click next, follow directions, restart computer. Did that fix the problem?
    Changes are fully reversible, it does not erase your current or past files. If the first date that you went back to does not fix it, try an even earlier date. You can always go forward in dates too.
Connection Windows XP
