Hay guys , my X-boyfriend recently me got into computer games and I really want to play Crysis, The Sims (I love that game) and other new games. The computer needs to be upgradeable and last a long time because I dont know what games I will play in the future.
I really don't know much about building a computer but my friend promised to help.
I found these parts below with a little research and I was wondering what you guys think?
I am worried about heating issues and that the parts are not compatible.
If you have any suggestions on parts that will go better with the system just let me know.
I especially need help with the motherboard, those things just confuse me.
Anything I am forgetting or any general tips to build a computer?
Thanks for the help
Jen
Processor
AMD Athlon 64 X2 6000+ Windsor 3.0GHz 2 x 1MB L2 Cache Socket AM2 Dual-Core Processor – Retail – 159.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103773
Power Supply
Rosewill RX950-S-B ATX 12V v2.2 & EPS 12V v2.91 950W Power Supply 100 - 240 V TUV, FCC, UL, CE, ROHS – Retail - 240
Video Card
VGA 768-P2-N831-AR GeForce 8800GTX 768MB 384-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card – Retail – 500.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130072&Tpk=EVGA%2b768-P2-N831-AR
Case
Thermaltake Armor Series VA8000BWS Black Aluminum / Steel ATX Full Tower Computer Case – Retail – 89.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133154&Tpk=Thermaltake%2bArmor%2bSeries%2bVA8000BWS%2bBlack%2bAluminum
Ram - Not sure on what I want to go with here
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory – Retail – 46.99 x3 – 100.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231098
G.SKILL 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail – 105.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
Motherboard
ASUS M2N32-SLI Deluxe Wireless Edition AM2 NVIDIA nForce 590 SLI MCP ATX AMD Motherboard – 169.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131011
Hard Drives
Western Digital Caviar GP WD10EACS 1TB 5400 to 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive – OEM – 270.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136151&Tpk=Western%2bDigital%2bCaviar%2bGP%2bWD10EACS
Western Digital Raptor WD1500ADFD 150GB 10,000 RPM 16MB Cache Serial ATA150 Hard Drive - OEM – 169.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136012&Tpk=Western%2bDigital%2bRaptor%2bWD1500ADFD
Disk Drives
ASUS Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 14X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 20X DVD±R DVD Burner with LightScribe – Retail – 40.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135156
Thanks again!
Thanks for the help
Jen
Processor
Power Supply
Video Card
Case
Motherboard
Hard Drives
Disk Drives
Thanks again!
