Tom's Hardware > Forum > Storage > Hard Disks > Help choosing external dive enclosure
Forum Storage : Hard Disks - Help choosing external dive enclosure
I have developed a sort of PC 'graveyard' of 5 or so old towers (heh, sound familiar)
What i would like to do is attach an external drive enclosure to my currant PC and pull the old drives out to
1) try and recover any data i may need from them and
2) completely wipe them before throwing away or donating the systems
Need some help choosing the right enclosure. I have both SATA and IDE, and both 3.5 and 2.5 inch drives.
Are there enclosures that accept both sizes and connections? I can't seem to locate one.
Also my MB has an sternal SATA connection. Should i find one that supports this connection or is there not much difference from USB 2.0?
TIA
Racer
Sponsored Links
Ii think you can only get an enclosure that excepts both sizes with one type of connection.
Reply to Ragsters
There are 846 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
