Tom's Hardware Forums » CPU & Components » Power Supplies, PC Cases & Case Mods » Need Drive Cage Recommendation for my Case
Word :   Username :
Bottom
Author
 Thread : Need Drive Cage Recommendation for my Case
Profile: old hand
More Information
Hi Gents,
I'm not a case expert, so I need some advice. I currently have a home server, built in a Thermaltake Armor case. I'm currently using 3 of their iCage units to hold hard drives. Each iCage converts three 5 1/4" bays to three 3 1/2" bays, and has a 120mm fan in the front. The 3 iCage units are currently holding 8 hard drives.
I have a need for more hard drives in this server, but cases that hold more than about 8-9 drives get into the realm of enterprise-level server cases, costing upwards of $400-$700. I'd rather look for a less expensive solution.
I'd like to replace the iCage units with another kind of cage that would convert three 5 1/4" bays to four or five 3 1/2" bays. I found a nice looking one by Icy Dock, but I'm going to run into a problem. The Thermaltake case has a quick-insert/quick-release mechanism for the 5 1/4" devices, and to facilitate this, there are small metal flanges separating each 5 1/4" bay. The iCage has horizontal, front-to-back slots in the side of it to allow you to slide the iCage into the 3 bays (with the flanges going into the slots), and the flanges then hold in in place. The Icy Dock enclosure doesn't have any slots, so it's not going to slide into the 3 bays, the flanges will block it.
Does anyone know of a solution? Is there another enclosure with slots similar to the iCage that would mount more than 3 HDs in the three 5 1/4" slots? Should I just use a dremmel tool or jigsaw and cut off the flanges so that the Icy Dock enclosures would mount? I have a friend who has a machine shop (drill press/small milling machine, etc.), should I just have him make three custom metal cubes that would mount the drives (difficult)?
- SomeJoe7777
"Did he dazzle you with his extensive knowledge of mineral water? Or was it his in-depth analysis of, uh, uh, Marky Mark that finally reeled you in?" - Troy Dyer (Ethan Hawke), Reality Bites, 1994
Google Ads
News
WD intros 120 GB portable Passport hard drive
Published on February 07, 2006
Western Digital (WD) today announced a 120 GB version of its portable "Passport" hard drive series. Read more
Supertalent Has the Smallest USB Flash Drive
Published on June 03, 2008
Flash memory has reached densities at which the manufacturers now focus on reducing the product size. Supertalent impressed us by providing its press release on the smallest thumb drive we’ve ever seen. Read more
Lian-Li intros 10-slot "CrossFire X" case
Published on January 12, 2008
High-end case maker Lian-Li has found the solution to adding double slot cards to a motherboard's lowest slot: They've added more slots! Read more
Intel enters the flash drive business
Published on March 12, 2007
Intel has entered the flash drive business by announcing its Z-U130 flash drive. Using NAND flash technology, the drive will come in 1, 2, 4 and 8 GB sizes and use a USB connector. Intel claims the drive will be speedy and will read at 28 MB/sec and write at 20 MB/sec. Read more
Latest Reviews & Articles
Stalker: Clear Sky--Is Your System Ready?
Published on September 30, 2008
Thinking about picking up the latest update to Stalker, but not sure if your graphics subsystem can handle it? Hang on as we take you through a performance tour and demonstrate how the game has been prettied up. Read more
Part 4: Avivo HD vs. PureVideo HD
Published on September 29, 2008
The 780G chipset/Radeon HD 3200 and the MCP78S chipset/GeForce 8200 provide the first integrated graphics solutions that can accelerate Blu-ray playback. We dig deep into how well they work with high-quality Blu-ray 1080p video playback. Read more
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
Maxtor's Shared Storage Does NAS At Home
Published on September 25, 2008
What do you do with all the data you collect at home? Network attached storage is the solution. We test Maxtor's Shared Storage II and find that it is also suitable for use in small businesses. Read more
