So I just got the Swift tech Ultra water cooling kit, and I went to think about how to install it in my case, which is a Antec P182, beautiful case with lots of good things in it BUT it is just too small. To get the water cooling kit in I would need to remove my extra hard drives and mess with so much stuff it would just be nasty.
SO I am after a new case, with the two main aims:
1) I want build quality and size.
2) Secondly it would be even better if it was designed to be used with water cooling.
Damo, head over to OC Forums and xtreme forums and spend a few days looking at the thousands of case mods there. You'll find what your looking for plus tons of real WC info.
Minimal Modding, outside is fine with me. I really like my P182 but size is just too small.
P190 is an alternative but I dont want or need another power supply.
CoolerMaster Stacker 810 - Extremely large case with some variations able to house a PSU at the top or bottom. Offers flexibility for other additions and customizations.
------------------------------Swiftech Mcres-Micro Reservoir, MCP655 Pump, D-tek Fuzion CPU Waterblock w/nozzle kit, Thermaltake Toughpower 1200, Swiftech Stealth GPU Waterblock, 2 external dual 120mm rads (each with four 120mm fans in "push-pull" )
Reply to phreejak
Whats the Lian Li like if I wanted to install the radiator on the outside? i.e. do I need to drill a hole in the case to get the tubes going in. Seems a tad pointless to buy a nice case like that then start drilling holes all through it.
if you look at the pic of the lian li there are a couple of holes in the back for WC
another option is the antec 900 (g2 ) i have this case and im happy with it but it is 1 or 2 inches to short for my cable managment
also there is a MASSIVE thermatake case that has built in water cooling not cheap but its all ready to go in one box
Gigabyte Aurora; I use it, works well. Has those nice grommeted holes for tubing, made of aluminum and light, 2x120mm fans and room for external 2x120mm radiator on the outside.
------------------------------The Pastafarian belief of heaven stresses that it contains beer volcanoes and a stripper factory. Hell is oddly similar, except that the beer is stale, and the strippers have VD
Reply to rubix_1011
Cooler Master cosmos either the S or the 1000. Personally I like the 1000. you can fit a dual 120mm radiator up top. I believe the S will take a tripple 120mm radiator. both cases large and built solid.
