ok im going to buy an antec 900 case so ill have 4 reg case fans and the top 200 or w/e fan, ill have 2 front fans, im assuming they should both be intake, the ill have 1 rear fan, presumably exhaust, then ill have 1 window fan, should that be intake or exhaust, and then what should the top fan be set as.
also i was wondering what should i set my cpu cooler's fan to intake or exhaust, ill be getting a scythe ninja 2 rev b, and also what direction should i have the fan pointing on it,
lastly do you guys think thatll be enough case cooling for a p35 ds3l with a q6600 and a 8800gt,
thanks much for the advice
