Final Edit: Complete reinstall worked.
Edit: trying a complete reinstall of vista, hopefully that does the trick or I will be SOL with a massive headach on my hands. Note to self, use restore points frequently when doing a new build incase of noob situations like the one I just put myself in.
Just put together a system tonight and its my first build. Everything has been going smooth until after I got the OS installed. Vista 64bit OS installed fine and when I was playing around tweaking settings I changed the screen resolution up a bit and now I keep getting a black screen with a mesage "out of frequecy" then the monitor goes into powermanagement mode. I can get into bios and to the OS load screen just fine but when it gets to the point where the OS would come up I get the black screen and error again. Tried starting in safemode to change the resolution back but with no luck, same thing happens. Anyone have any ideas?
