Tom's Hardware > Forum > Homebuilt Systems > New System Build > Please double-check my system build before I order tomorrow morning!!
Forum Homebuilt Systems : New System Build - Please double-check my system build before I order tomorrow morning!!
Hey guys,
Tomorrow is the last day I can order this, because I'm leaving the country and won't be able to do anything as of 3pm EST tomorrow, so quick responses would be GREATLY appreciated.
I've constructed this system, but I'm no pro, so I was hoping somebody could double check that I haven't made any poor choices:
Motherboard $299.99 http://www.newegg.com/Product/Prod [...] 6813131074
Processor $279.99 http://www.newegg.com/Product/Prod [...] 6819115028
Graphics Card*/** $449.99 http://www.newegg.com/Product/Prod [...] 6814150232
Memory* $134.99 http://www.newegg.com/Product/Prod [...] 6820145184
Harddrive* $104.99 http://www.newegg.com/Product/Prod [...] 6822152052
Power Supply** $139.99 http://www.newegg.com/Product/Prod [...] 6817182096
Case* $109.99 http://www.newegg.com/Product/Prod [...] 6811119103
CD / DVD $39.99 http://www.newegg.com/Product/Prod [...] 6827135156
Monitor* $359.99 http://www.newegg.com/Product/Prod [...] 6824112011
I built it with future SLI (another GTX, when they're cheaper) in mind, and I want to be able to play games like World in Conflict and Crysis. Also room for another 4GB memory upgrade.
Thanks,
phrzn
Sponsored Links
780i supports dual & tri SLI. I suggest you take a look:
http://www.newegg.com/Product/Prod [...] 4&Tpk=780i
I wouldn't build such a highend rig with that psu. Heck, I wouldn't use anything but tier 1:
http://www.tomswiki.com/page/Tiere [...] ngs?t=anon
Reply to akhilles
- 0 +
eveything is great if you got the money, but a word of advice, that mobo is a dead-end in terms of upgrade, its the last in it's line, plus, its abit of an overkill if your not going to OC. go with a P5N32-E, you'll save quite alot and still get 2 x16 slots.
that PSU is just sick overkill. a system like that, running with even GTX's in SLI we'll need a 700W PSU. max
it's a total waste of money
Reply to GJX
- 0 +
Buy the 780i if you want sli ^^^^^
Change your cpu to a Q6600
Buy a 8800GT or new GTS instead off the GTX
Change your psu to a PCP&C or Seasonic (about 700W)
Message edited by ramo on 12-18-2007 at 06:01:23 PM
Reply to ramo
There are 1223 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
