Wow, I am glad I found this forum. You guys really seem to know your stuff. I apologize for asking for help on my first post but I am extremely frustrated and have been doing hours of research with no luck. Maybe someone here can help? Here is my system. This was a new build and put together 2 weeks ago...
Intel Core 2 Quad Q6600
Zalman CNPS9500 Cooler
Gigabyte GA-P35-DS4 Rev 2 with F11 BIOS
2GB Kingston DDR2800 Value RAM
Antec TruePower 650w PSU
Antec P180 Case
Windows XP SP2
I have overclocked this system to 3.0GHz and 3.2GHz. Both overclocks are extremely stable and run the newest version of Prime95 for 24-hours without error. The problem I am having is that many times during a reboot or a boot from a cold PC, the machine resets itself after the Gigabyte screen and I lose the following overclock settings...
CPU HOST CLOCK CONTROL: (Changes from "enabled" to "disabled")
SYSTEM MEMORY MULTIPLIER: (Changes from "2.4" to "auto")
DRAM TIMING SELECTABLE: (Changes from "manual" to "auto")
When the overclocking settings are disabled, my system always boots fine. Its when I try to overclock, even by a little bit, I seem to have a 50:50 chance of the machine resetting. I have been trading emails with Gigabyte support but it takes 2-3 days to get a response.
Could this be a RAM issue? My RAM is technically supported. I have tried setting the timing to both auto and manual at 5-5-5-18 and 5-5-5-15. This does nothing. I alwyas have the voltages set to auto and it should be good since the memory uses 1.8v.
Any other ideas? I have tried changing every setting but I am still able to get the machine to reset. I have tried both the F6 and F11 BIOs and neither fixed the problem.
Help!
Thanks in advance
Antec P180 Case
Windows XP SP2
Help!
Thanks in advance
