Tom's Hardware Forums » Overclocking » Motherboards » 790i SLI Problem Any Ideas?
Word :   Username :
Bottom
Author
 Thread : 790i SLI Problem Any Ideas?
Profile: journeyman
More Information
I've recently got a new Evga 790i motherboard and when gaming the screen freezes.I have to turn the computer off and on again and get a message telling me that the display drivers have stopped working and that the problem has been resolved but it's making the f'ing thing unusable.When i take out the 2nd graphics card i don't have any problems.I have installed all the latest drivers.Could it be because the drivers aren't quite there yet ? Any suggestions appreciated.
Related Product
You tell me what I do.
Profile: Ancient Poster
More Information
that clearly is driver problem.try to download the driver direct from nvidia.if problem exist try the beta driver avaiblable.
if would be more helpful if you lsit your full spec.and i guess you are using windows vista.
Profile: journeyman
More Information
All my specs listed in member config if that helps.This is really doing my head in because ive just splashed out on another g card and i can't use it.
Profile: journeyman
More Information
vista 64 by the way
More Information
just what i thought.vista and worse still 64bit!lol thats why i stay with 32bit xp ro vista.
More Information
how much did that cost you btw?its one of the top sys.i know its hard for you when all that money dont work out.
Profile: journeyman
More Information
bout £3500 the new graphics card was only £150 off ebay. I'm getting over 300 fps on counter strike when it's working and crysis plays very well.much better than the dell xps720 sli i had and had too return they are useless
More Information
£3500!!!
i neva spend or build anything above £1200 but i guess its the CPU that cost the most.
anyway have you try download the latest drivers from nvidia?
Profile: journeyman
More Information
downloaded from guru3d ,evga and nvidia ,it's weird.No problems at all with 1 card.I wouldn't of got the 790i if i didn't want to sli.
More Information
yeah if you want SLI there is no better choice then 790i.because the 780i,750i just a remask of the 680i and 650i.
have you tried the Beta driver though?
to be honest my new rig would be SLI.so 790i is what im looking at.but i will see how things move on.
Right you are Ken!
Profile: member
More Information
Do you have the latest bios version?
Also I'd like to back up what 'iluvgillgill' said....get the card drivers direct from Nvida.
Message edited by 1971Rhino on 06-03-2008 at 02:00:34 AM
E8400 @ 3.8Ghz linked and synched with 2GB Corsair DDR3 @ 1700MHz/EGVA 790i Ultra/2 x 9600GT in SLI/2 x 500 GB Seagate HDD/Samsung 24" 2493HM/Antec 900
Profile: member
More Information
A lot of the 790i Ultra boards are having problems with freezing under almost any load!
I've got one with twin 8800GTX OC's in SLI, and it was freezing both with and without SLI. It was freezing in Win XP Pro and Vista Ultimate, both 32 bit versions. Sometimes it would freeze up solid when gaming or using the TV tuner, and sometimes it would freeze just sitting idle.
I RMA'd the first board and I've got the second one in and running, and it's starting to do the same thing. It seems to be less frequent, but it freezes up even with everything running at stock speeds.
If it keeps it up or they don't find a fix soon, I'll be asking for a third board. On the EVGA forums, there are plenty of people who are on their fourth and fifth boards. Many, perhaps even most users don't have any problem, but from the EVGA forums and other board makers forums, it's a sizeable number of the 790 boards th at are having trouble.
There are an almost uncountable number of solutions posted, but most eventually start having the problem again.
The best guess of everybody is that it's a problem with the nVidia chipset, and not the individual board makers.
I guess they also had problems with the early 680's and 780 boards. The computer is fast as hell when it's running...., but without warning, it'll just freeze solid. The video and audio just stop and it doesn't respond to any inputs from mouse or keyboard. All you can do is push the power or reset button and reboot.
It'll start right up again and run fine for perhaps a couple of days, or perhaps a couple of minutes, and then do it again.
For a high-end board, it should at least be rock stable at stock settings!
Google Ads
News
Nvidia To Launch NForce 790i Chipset In Q2
Published on January 29, 2008
Nvidia is planning to launch the next generation nForce 790i chipset in the second quarter this year. Read more
ATI Catalyst drivers have a problem
Published on August 27, 2004
ATI has a problem in the latest Catalyst drivers. Read more
CeBIT 2008: Gigabyte 2, High-End X48 Motherboards, 790i SLI unleashed.
Published on March 07, 2008
Gigabyte is showing two new high-end motherboards based on Intel's X48 chipset, and a new motherboard based on Nvidia's 790a SLI chipset at its CeBIT stand. Read more
CeBIT 2008: DFI's High-End Under The Spotlight
Published on March 10, 2008
Well known among overlockers, DFI showed its latest board built on a X48, nForce 790i (C73 + MCP55) and AMD 780 (RS780D +SB700). Here are well designed boards with two PCI 16x slots (except for the ADM card), digital power supply stage at 8 phase (which makes sure there isn't any voltage drop when the processor's in peak), capacitors using solid electrolyte and a Thermalright cooling system. In other words, we have the best components for overclocking. Read more
Latest Reviews & Articles
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
Maxtor's Shared Storage Does NAS At Home
Published on September 25, 2008
What do you do with all the data you collect at home? Network attached storage is the solution. We test Maxtor's Shared Storage II and find that it is also suitable for use in small businesses. Read more
SLI & Centrino 2: Gaming Laptops Battle
Published on September 24, 2008
Take four gaming laptops. Arm two of them with SLI and make the others Centrino 2-compatible. You're looking at a high-end collection of the latest mobile technology battling it out for benchmark supremacy and your hard-earned dollars. Read more
1,000 GB: Three Samsung TB Drives
Published on September 23, 2008
Storage vendors split the desktop hard drive market into performance, mainstream, and energy-efficient products. We looked at Samsung’s Spinpoint F, the RAID version and the EcoGreen F to discover how a 1,000 GB drive differs from another. Read more
