I have an E8400 OC'ed to 3.6 GHZ with a zalman 7000B alcu. I think my temps are to high and I think they need to be calibrated.I get 44*C idle and 56*C under load while gaming.I want to change the fan with a zalman 9500 led is it worth it?
E8400 @ 3.6 w/ AC Freezer 7 Pro
37c idle
56c load
RealTemp 2.60
Message edited by kpo6969 on 06-01-2008 at 11:27:53 PM
------------------------------ P35-DS3L Rev 2 bios F9C l E8400 @ 3.6Ghz @ 1.232v l OCZ Vendetta 2 /LGA775 Bolt-Thru l 4GB G.Skill 8800PI@1000mhz 4:5 @ 1.87v l WD3200AAKS 320GB l Evga 8800GTS 512 l X-Fi Xtreme Music l Corsair HX520 l Antec Sonata III 500 l Vista32 SP2 l Win7 X64 7600
Reply to kpo6969
E8400 @ 3.6GHz using CNPS9700LED
high 20s - low 30s idle
46-47c after 12+ hours of Prime95
~20C ambient temperature with case open (don't remember ever having a PC with closed case! lol)
I barely had to up the voltage on it, so probably why it's running so damn cool
9700 is an awesome cooler, but it's far from cheap. TRUE extreme with Scythe is a solution that offers same for less (wish I knew that before I bought 9700!!) From what I heard, Zalman 7000b is barely better than Intel stock coolers, so I'd definitely switch.
Message edited by dechy on 06-03-2008 at 08:24:17 PM
