edited 26/12:
Well I ordered all the components, the list is this:
http://www.amazon.com/gp/richpub/li...CXLUZL4JR/ref=cm_lm_pthnk_view?ie=UTF8&lm_bb=
Some components got more expensive (Others got more cheap ) but when I buy them they cost what I wrote next:
Intel Core 2 Quad Q6600
http://www.amazon.com/Intel-Q6600-quad-core-processor-2-40GHz/dp/B000LRMR26/ref=cm_lmf_tit_1
279.99
Thermaltake W0117RU ToughPower 750W with Active PFC Dual Fan
http://www.amazon.com/gp/product/B0...UTF8&coliid=IU7NOLTKJYTCG&colid=3NHL2I4EHCL6Q
164.51
EVGA GeForce 8800 GTS (512mb)
http://www.amazon.com/EVGA-GeForce-8800-Video-Card/dp/B00114O9EC/ref=cm_lmf_tit_3
359.99
Asus STRIKER EXTREME LGA 775 NVIDIA nForce 680i SLI ATX
http://www.amazon.com/gp/product/B0...TF8&coliid=I3JH0Y67IZ18YB&colid=3NHL2I4EHCL6Q
319.99
Thermaltake VA8003BWS ATX Full Tower Case with 25CM Fan
http://www.amazon.com/gp/product/B0...UTF8&coliid=IX5VQZWHZX7RJ&colid=3NHL2I4EHCL6Q
166.75
Western Digital WD1500AHFDRTL Raptor X 150GB SATA/150
http://www.amazon.com/gp/product/B0...UTF8&coliid=IGROFVRC2X3KL&colid=3NHL2I4EHCL6Q
169.99
Western Digital WD5000KSRTL Caviar 500 GB SATA
http://www.amazon.com/gp/product/B0...UTF8&coliid=I4I83DLIMJ36F&colid=3NHL2I4EHCL6Q
127.46
Corsair 2GB PC6400 800MHz
http://www.amazon.com/Corsair-PC6400-800MHz-240-Pin-TWIN2X2048-6400/dp/B000CDLCGG/ref=cm_lmf_tit_8
74.99
Zalman CNPS9700LED Ultra Quiet Cpu Cooler
http://www.amazon.com/gp/product/B0...=UTF8&coliid=I1F9EIYZV7V2&colid=3NHL2I4EHCL6Q
73.51
Logitech NEW G5 Laser Mouse
http://www.amazon.com/Logitech-NEW-G5-Laser-Mouse/dp/B000ODN7VM/ref=cm_lmf_tit_10
54.99
Logitech G11 Gaming Keyboard
http://www.amazon.com/Logitech-967929-0403-G11-Gaming-Keyboard/dp/B000GP844S/ref=cm_lmf_tit_11
58.99
Oem Sony 20x Dual Layer DVD+Rw/-Rw, Black
http://www.amazon.com/gp/product/B0...TF8&coliid=I269J4QZPBTY4F&colid=3NHL2I4EHCL6Q
39.99
Grand total: 1891.15
With Shipping & Handling: 2067.32
I didn't buy a monitor but That's for later. I stayed close to my budget so is ok. Thanks for all the fedback I got. When I finally get all the components here (I guess that could be around late January or maybe February) I post how was it when finished building
_____________________________________________
-------------first post------------------------------
Hi, well this is the first time I want to build a new computer and to be honest the computer is going to be mostly for gaming and is intended to be as most high end possibly. I don't know too much about hardware but I think I got the basics covered. My budget is about 1800 $ (although I could spend 200 more) and need to buy before 31/12 because I'm from venezuela and the amount of dollars you can have is regulated. Also I only buy at amazon since neeweg or other pages don't send their stuff here. Ok now to the components, I been reading a lot and got this system build, lets see what everybody here can recommend or correct me:
The list:
--- edited (see final list above) ---
When I put all of this in my shopping list the total is 1803.54 $
Ok now I think is important to say the next:
1) The Power supply theme I don't know much about it. If that ps that I chosse isn't good please explain why it is
2) The configuration of the hard drives I either don't know too well how are they suposed to be put, I just read that combination is great for gaming
3) Overclocking I have no idea how to do it but I plan to learn how to since the procesor and the video card I chosse I read that they overclock very well and give great bang for the buck
4) The sound card is really necesary? The computer is for gaming and again I read it's great for gaming to have a good sound card
Anyone had anything to say about this? should I put another product instead of any of the products I use there?
Sorry if I sound like a robot but my english is a little basic... It took me 30 min to write all of this
Thanks
edited 26/12:
279.99
164.51
359.99
319.99
166.75
169.99
127.46
74.99
73.51
54.99
58.99
39.99
The list:
Thanks
