So I finally bought my system. When I installed it in the case it would not run. So I took it out, because the problem was the CPU 4-pin power cable was awkwardly placed and did not fit well. It ran perfectly fine outside my system, so I waited for the next day to put it back in. When I put it back in, this time with the CPU power supply firmly in position, it would not start. At all. Before, the fans would spin for a second and then turn off. Now it does nothing. Took it out of the case (onto a wood surface). Nothing. I have this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812120803
that i used on my other computer. The light is on when it runs. When I turn on the PSU, the light turns off. I also have to use a 3-prong to 2-prong adapter from the power strip to the wall.
**edit**
my specs:
2 gb ADATA DDR2 800 RAM (says this needs 2.0 to 2.1v, but I can't change it because the comp wont start!)
GA-P35-D3SL mobo
Antec NeoHE 500W PSU (used this on another computer, worked fine)
Pentium dual-core E2160
Cooler Master Hyper TX coolder (used this on another computer too)
HIS Radeon HD 3850 512MB
what is going on?
**edit**
my specs:
GA-P35-D3SL mobo
what is going on?
