hey folks,
am planning to get
asus maximum extreme,
intel q6600 quad cpu
asus or gigabyte geforce 8800GT DDR3 512 VGA (which brand would you recommend???)
kingston 2 x 1 GB DDR3 1800 MHz RAM
seagate barracuda 7200.10 (750 GB) and 7200.9 (500 GB) SATA 2 HDDs
arctic freezer 7 pro cooler (is this noisy?? or silent??)
I'll be using large databases, some high-speed gaming.
I need your recommendations for the following:
1-a case, if possible mini, or at least not larger than midi, right side will be placed to the wall, so I need to have the fans on the left side (or preferable on the front), usb and if possible also headphone/speaker out at the FRONT, it should keep the temp quite down and it should be QUIET!! Something where I wouldn need to get additional coolers or power sources would be better.
2-do I need an additional power unit for this? if so, what would you recommend?? I'm planning to more RAM in the future, and fill all 4 slots. And maybe, if it is possible, to install a second VGA (is this possible??)
many thanks in advance!!
o.m.
am planning to get
o.m.
