I've finished my build, but there is a couple of strange things happening...
My Hard Disk (250GB Western Digital Caviar SE16 SATA II) is only showing in Windows (XP Home) and Everest as 127mb (not 250).
The second one is that Everest shows three temp measures for my CPU (Core 2 Duo E6750). It shows a main temp of 17c (63f), Core 1 as 30c (86f) and core 2 as 27c (81f).
Even the main temp of 17c (63f) seems high to me. It's not under any major load, just surfing and dl a torrent.
I'm using the stock cooler with all my system at stock. The rest of my kit is below. Any help would be appreciated... Thanks guys.
1 x Gainward GeForce Bliss 8800GT 512MB PCI-E DVI x 2
1 x Geil Ultra DDR2 2.0GB PC6400 Dual Channel memory kit (2 x 1GB) 800MHz (4-4-4-12) +Aluminium heat spreader
1 x Intel CPU Core 2 Duo E6750 2.66GHz 1333FSB LGA775 4MB cache Retail inc.Fan
1 x 250GB Western Digital Caviar SE16 SATA II 300 7200rpm 16MB cache Hard Disk Drive oem
1 x Asus Motherboard P5K Intel P35 LGA775 Core2 Quad / Core2 Extreme / Core2 Duo PCI-E Heat Pipe ATX
I've also got my old IDE 60gb HD and DVD burner connected up. Power supply is a ColorSit 550w.
