1000$~ gaming build..plz spot bottlenecks/problems
im newb to this stuff.and purchasing these parts in 2 days plz spot problems!! i guess im going with an "amd" build after little research..still feeling clueless and gotta order in 2 days lol
Will This RUn World of Warcraft to its fullesT?
motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128045
GIGABYTE GA-M61SME-S2 AM2 NVIDIA GeForce 6100 Micro ATX AMD Motherboard
processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103767
AMD Athlon 64 X2 5200+ Windsor 2.6GHz 2 x 1MB L2 Cache Socket AM2 65W Dual-Core Processor
ram(is this **** raM? seems cheap)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820161677
WINTEC AMPO 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 667
video card
http://www.newegg.com/Product/Product.asp?Item=N82E16814102712
SAPPHIRE 100213 Radeon HD 2900GT 256MB 256-bit GDDR3 PCI Express x16 HDCP Ready CrossFire Supported Video Card
power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139001
CORSAIR CMPSU-520HX ATX12V v2.2 and EPS12V 2.91 520W Power Supply 100
Harddrive
http://www.newegg.com/Shopping/ShoppingItem.aspx?ItemList=N82E16822148262
OPEN TO ANY AND ALL SUGGESTIONS!!
9 answers Last reply
More about 1000 gaming build spot bottlenecks problems
  1. kdubble4,
    the ram is cheap.....look at the brand.....i would recommend corsair or even ocz memory. i would also look into going with ati's 512mb card to help you for future games.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814102713
  2. now that i looked at the board.....that board that u have chosen is for sli
    (nvidia chipset) not cf. if u have ur heart set on that board choose the 8800 gt for performance/value
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814130296
  3. Whats your budget? If it about $180 just for the CPU and Motherboard, I recommend you go with a P35-DS3L/R and a E2180, you can OC the E2180 to 3Ghz+ and it will beat the 5200 in every bench mark, even if the 5200 is OCed.
    Here are the 3.2Ghz results for the E2180:
    http://www.mediafire.com/imageview.php?quickkey=bdezm31g2zb&thumb=4
    http://www.mediafire.com/imageview.php?quickkey=ftmobskndyt&thumb=4
    http://www.mediafire.com/imageview.php?quickkey=4mp2jnommvw&thumb=4
    http://www.mediafire.com/imageview.php?quickkey=1bdcoadcns3&thumb=4
    http://valid.x86-secret.com/show_oc.php?id=282308
  4. intel is stomping amd and has been for sometime. go intel & nvidia=beast
  5. http://www.newegg.com/Product/Product.aspx?Item=N82E16814102717
    For $5 more after S/H you could get this card. I agree with shadow, go with the E2180+P35-DS3L and save a little dough and get more speed. That's the route I'll most likely go myself.
  6. From Jab-Tech.com
    Cooling: Thermalright Ultima 90 + Scythe S-Flex Fan - SFF21F + Artic Silver 5 - $66
    http://jab-tech.com/product.php?productid=3852
    http://jab-tech.com/product.php?productid=3257
    http://jab-tech.com/product.php?productid=1957
    Mobo: GIGABYTE GA-P35-DS3L Rev. 2.0 - $88
    http://clubit.com/product_detail.cfm?itemno=CA4830813
    PSU: CORSAIR HX CMPSU-520HX - $100
    http://clubit.com/product_detail.cfm?itemno=CA6200026
    OS: MICROSOFT Windows Vista 32-Bit Home Premium - $97
    http://clubit.com/product_detail.cfm?itemno=CA7252236
    GPU: EVGA GeForce 8800GT 512MB - $260
    http://clubit.com/product_detail.cfm?itemno=CA9602859
    CPU: Intel Dual-Core E2160 Allendale 1.8GHz 1MB L2 Cache LGA 775 Processor - $83
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819116036
    Case: COOLER MASTER Centurion 5 - $50
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119068
    Drive: SAMSUNG Black SATA DVD Burner - $34
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827151153
    Ram: A-DATA Extreme Edition 2GB - $50
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820211174
    HDD: Western Digital Caviar RE WD3200YS 320GB - $90
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822136053
    Total: $918
    You can take way the Ultima and save 66$, which will put it at $852. Which with the extra cash, maybe upgrade it to the new 8800GTS and stay below the 1000$ mark.
  7. lockdown thx for posting that..id appreciate if more people would post builds like that lol..does anyone see any problems with lockdown's build? because if not i will more than likely order straight from those links and get wat he posted ty for taking the time to do that man
  8. ^the build is great, but I recommend that you get better RAM like this one:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820145590
    its $37 after MIR. I personally have used this RAM and it can run at pretty high speeds with a bit loose timing. I have one running @ ~970Mhz.
  9. instead of getting the Thermalright Ultima 90 + Scythe S-Flex Fan cant i jsut get http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
    doesnt that case have all the cooling **** i need?
New Build Systems Product
