This is going to sound a bit odd, but believe it or not, I hear tiny crackling sounds sometimes during RAM read/writes. Not all the time, and only under idle circumstances. It has something to do with over clocking, because they are absent from stock settings... And further, I have traced it to the RAM.
If I am playing music with WMP 11 or playing a game or some such, I can hear periodic crackles from the speakers. Maybe every 4 seconds there is one, sometimes it skips a few seconds before doing it, but its defiantly not a constant.
Thats what drives me nuts, it's so irregular, but it does happen when I click on something that does a new action, not always, so back to the RAM... when its Blending, and it blends fine, its immune to the crackling.
As in, when the ram is in a fair amount of continuous use, it does not crackle at all. Plays music flawlessly.
My belief, if I had to guess? I may have damaged the actual Pin of a ground that connects from the RAM slot to the MoBo, and this is 1: causing the power through the broken connection to not ground, and short on the nearest whatever.. or 2: simply doesn't allow for a ground when needed, and causes the same crackle from lack of the termination.
That could explain why while at full use, the RAM doesnt have this problem, and doesnt make the crackle sound, because it's using its full complement of grounds, and not just data local ones for minor ram accesses, such as Midi buffering in games for background effects and music, and the refreshing of your WMP Audio playback buffer.
Any guesses would be most helpful! It could be related to the NB, I guess... as Data passes between it and all that Via the FSB.
Got me!
--Lupi
Got me!
--Lupi
