Tom's Hardware > Forum > CPU & Components > Sound Cards > Better to switch to built-in sound chip ?
Forum CPU & Components : Sound Cards - Better to switch to built-in sound chip ?
Hi ...
Now I'm using a PC with Gigabyte 945P-S3 rev.3.3 with CORE 2 Duo 2.133GHz (E6420) and Geforce 7900GT..2GB of 667MHZ DDR2 main memory...With SATA II Maxtor 160GB storage..
I use for sound the "ancient" Creative Sound blaster 5.1 live (S0100) chip from Creative...with discountinued driver support from long time ago from the company...
My question is that : Will I lose in terms of performance when I take off the PCI Creative sound card to replace it with the built-in one in my Gigabyte board or not ? in terms of games,compatibilty,and general performance ?? I use both XP prof. and Vista 32bit HomePremium ? Does it worth it ? is it better to change to the built-in sound or not ???
Sponsored Links
To improve on onboard sound you are looking at an entry level higher end sound card, which will cost you around $100. If you have the money to get a good new card, go for it. On the budget is tight, try the onboard and see how it works. This card has gotten good reviews and there are Creative cards as well. I just don't think a cheap card will be worth the money
http://www.newegg.com/Product/Prod [...] 6829127002
Reply to g-paw
Just because the drivers are discontinued doesnt mean you cant still use it... or are you having issues? Vista support maybe?
The live should out perform the onboard. As g-paw said , try the onboard if you dont like it get something else
------------------------------ "This thread made me strap on my lolerskates and head for my roflcopter."
Reply to chookman
The live! 5.1 is a great sound card. Much better than any onboard for XP. For vista creative should get their act together, on-board is better.
------------------------------ P4 3ghz Ht| Intel D865PERL| pc3200 1 (2x512mb)gig of ram 400mhz, 2.5-3-3-8| 80 gb Seagate Barracuda Hd, 300gb WD HD| Asus 7600gs| 1x Lg dvd reader/cd burner| 1x LG dvd burner 300w psu.
Reply to smokedyou911
There are 456 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
