Bought a new agp vid card to replace my dying A-I-W 9800, it's a EVGA 256-A8-N542-T2 Geforce 7600gs 256mb. Before I install it I'm wondering now if my power supply is too small for this card. It looks to be a no name "POWERUP LC-B400ATX"
Here's what it says on the sticker of the PS, hope it helps.
V- : VOLTAGE : CURRENT
INPUT : 115V- : 10A
: 230V- : 6A
V : +3.3V : +5V : +12V :-5V -12V +5VSB
OUTPUT : 28A : 40A : 17A : 0.3A 0.8A 2A
MAX ; 220W : 240W : 1.5W 9.6W 10W
: 380W
Sponsored Links
It should work, not saying it's a good PSU but that card shouldn't require that much power.
Reply to g-paw
Well, it's either testing it or checking if anyone have tried that combo already on the net.
I have a problem with lousy tire 5 PSU crashing the system while playing games, so I'm switching to a much better and more reliable PSU now.
Message edited by krillz on 01-04-2008 at 12:32:43 AM
Reply to krillz
From the card specs
"System Requirements:Minimum of a 350 Watt power supply. (Minimum recommended power supply with +12 Volt current rating of 18 Amp Amps.)"
Am I outta luck with my, if I'm reading it right, +12v 17a?
Reply to bigb41571
Yeah I had the same problem, I had only a single +12v rail as you, and that was trying to power everything with mobo/all the case fans and other things in found in there + the power consuming 88000 GTS.
Basically this produced rails to drop amps down causing the whole system to crash while playing.
But then again it depends on what other parts you have in the setup as well. Check out this one:
http://www.extreme.outervision.com [...] orlite.jsp
Helped me to get a recommended total W estimate.
Message edited by krillz on 01-04-2008 at 12:41:48 AM
Reply to krillz
Please replace your PSU ASAP. You will be happy you did, because those cheap PSUs die after about a year (max) or 6 months of use. Read this:
http://www.xtremesystems.org/forum [...] p?t=108088
and then get a PSU from the top tires.
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
If I try installing the card and it's not enough am I at a big risk of damaging the card itself?
Reply to bigb41571
You shouldn't have to worry about damaging the card, the worse that'll happen is that either it won't start or run like crap.
Reply to g-paw
thanks for all your answers
Reply to bigb41571
lol dont be so sure bout urself, ive had cheapy psu's burn motherboards ram and hard drives b4, but nvr vid cards
Reply to monste4321
Got the card in and running, so far no problems over 2 days, no thanks to my clumsy fingers.
Reply to bigb41571
Glad it's working. When you have the money or for your next new build would be good to get a better PSU
Reply to g-paw
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Power Supply Big Enough?
There are 1282 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
