Lately my laptop has been getting the blue screen of death on almost a regular basis, so I did a check disk...which froze at 14% (I ran it twice and the result was the same). So I connected the hd to another pc and used partitionmagic to scan it. Turns out there are 2 errors, there might be more but after the second one the scan automatically stops.
All it tells me is a section where the error is and that I should consult the online user manual (which holds no relevant information). So, my plan is to delete the partition (with partitionmagic), format the hd, and let the install cd do the rest. Will that fix the errors or bad sectors?
