I have a GTS 512 in the way and on EVGA's site theys state that they recommend a "Minimum recommended power supply with +12 Volt current rating of 26 Amp Amps."
Now I have a Thermaltake Toughpower 700w power supply that has 4 12v rails I think with 18amps on each.
Now Is evga saying that you if your powersupply only has one rail that It needs to support 26amps? Or is a dedicated rail to the GPU of 18amps sufficient?
You actually have a 56A max across all four rails, you can't just add them together to get the max value of the power supply. You should be fine with that card.
you could run 2 ultras, 4 hd's 2 dvd burners, aftermarket everything with that power supply. my brother has the same one and he run's all that stuff so don't worry and buy 2
Message edited by kpo6969 on 01-02-2008 at 09:30:29 PM
------------------------------ P35-DS3L Rev 2 bios F9C l E8400 @ 3.6Ghz @ 1.232v l OCZ Vendetta 2 /LGA775 Bolt-Thru l 4GB G.Skill 8800PI@1000mhz 4:5 @ 1.87v l WD3200AAKS 320GB l Evga 8800GTS 512 l X-Fi Xtreme Music l Corsair HX520 l Antec Sonata III 500 l Vista32 SP2 l Win7 X64 7600
Reply to kpo6969
I have the TOUGHPOWER 850WATT PSU with 62amps on the combined 12v rails and it works beautifully.Your 700watt will handle what you have 3 times over,so no worries.Goodluck.
Dahak
M2N32-SLI DELUXE WE
X2 5600+ STOCK (2.8GHZ)
2X1GIG DDR2 800 IN DC MODE
EVGA 8800GT SUPERCLOCKED
SMILIDON RAIDMAX GAMING CASE
ACER 22IN WS LCD 1680X1050
250GIG HD/320GIG HD
G5 GAMING MOUSE
LOGITECH Z-5500 5.1 SURROUND SYSTEM
500WATS CONTINUOUS,1000 PEAK
WIN XP MCE SP2
3DMARK05 15,686
3DMARK06 10,588
I have an Antec True Control II 550 PSU, with two +12V rails of 19A each. I beleave it is OK for my new NX8800GT video card, BUT: I´d like to know if I can use the dedicated PCI express power connector from my PSU or should I use the two-molex-to-PCI-express adapter included with the card in order to combine both rails. Could anyone set this straight to me?
hrm. I think you will be fine, use the pci express power connector.
I'm using a Thermaltake TR2 W0070RUC ATX 430W with 18amps on the 12V for my overclocked BFG 8800GTS 512mb. Rest of the system:
Amd x2 4800 939
2X512mb ddr
2 hdds
tv tuner
x-fi sound card
dvd
No stuttering, no freezing. The thing barely gets warm. In general I think people get too worked up about power requirements.
