I'm literally working on deciding my last component for my computer... the heatsink I will be using for my new rig. I don't know what will fit and I'm hoping someone can point me in the right direction. I've read a bunch of posts and I think ultimately I'll convert to a watercooling system, but in the meantime I want sufficient cooling! These are the components that I think affect the heatsinks I can use:
TRUE, I have both a xiggy and and a TRUE and the TRUE is still better from my personal tests. Could just be the berserk push pin trash, and it has a proprietary fan to heat sink holding design. Single fan. TRUE can hold 2 fans.
I have just purchased a very similar setup and only have the heatsink left to buy. I've heard the Xigmatek S1283 is the one to get but I live in Australia and I can't seem to buy it anywhere.
What would be the next best cooler which I can use to overclock a little.
My setup uses the same Motherboard and CPU as the OP but my case is the Antec 900. Any help would be appreciated.
