Tom's Hardware > Forum > Overclocking > General Discussions > Q6600 intended build, need help
Forum Overclocking : General Discussions - Q6600 intended build, need help
Hi, im buying some stuff to build a new pc in 2 more weeks. I dont use it heavily for nothing in special, just want it to work really fast for normal usage and be good enough to manage some games every once in a while. I want to overclock it lightly, maybe to 3,2 Ghz. Im ordering stuff overseas, so its really important for them to be reliable, DOA means i probably lost my money :(.
This is what im thinking:
ASUS P5K-E/WIFI-AP LGA 775 Intel P35 ATX Intel MotherboardRetail/www.newegg.com/Product/Product.aspx?Item=N82E16813131196
Intel Core 2 Quad Q6600 2.4GHz LGA 775 Processor - Retail
http://www.newegg.com/Product/Prod [...] 6819115017
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBPQ - Retail
http://www.newegg.com/Product/Prod [...] 6820231122
MSI NX8800GT 512M OC GeForce 8800 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
http://www.newegg.com/Product/Prod [...] 6814127329
Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Prod [...] 6822136073
ZALMAN 9500A 92mm 2 Ball CPU Cooler - Retail
http://www.newegg.com/Product/Prod [...] 6835118223
Thats it, would like to know if you think this would run ok and if you find any potential problem or easy upgrade.
Thank you,
Ignacio
Sponsored Links
For the cooler, I would change to the TRUE(Thermalright Ultra 120 Extreme), you can up the hard drive to the WD640GB its faster a bit. Video card, cpu, mobo looks fine. For the mobo you can get that one or one of the new p45 chipset P5Q-E or P5Q-Deluxe. Do you already have the case and psu?
Reply to Shadowthor
GA-P35-DS3L. Go WD 6400AAKS for a little more performance and storage. It's not much more either. Are you overclocking, if you are, a cheaper ACF7P will do fine unless you OC to 3.6, then you'll need the Zalman.
Reply to pcgamer12
Hi guys, thanks for the fast responces.
I have my old pc case and psu, i think ill try with those and then see what happens. Can anyone explain me breifly how important is to have good cases or psu?
I thought about the TRUE but since i only want to OC lightly(3,2 or maybe just a bit more) i thought it could be a little overkill. Tell me what you think about it.
Thanks,
Ignacio
Reply to pajarot
I say that most people that "just" want 3.0 or 3.2 end up going for more, because it's not all that hard to do, its free, and its fun!
It's best to be prepared.
Oh, get a OEM processor if you can find one!!!
--Lupi
Message edited by Lupiron on 06-12-2008 at 09:48:45 AM
Reply to Lupiron
A good case will be able to move air efficiently and quietly (hopefully) through it. If you are going to use an upper end HSF (read "large" ), make sure it will fit inside the case. Cheap PSU's may work fine. Or they may cause problems ranging from stability problems to a catastrophic failure that takes a motherboard with it. On the other hand, even a good quality, brand name PSU may be DOA.
Skip the Zalman. There's other things that work as well for less money - AC Freezer 7 Pro for example. Or work better for the same money - Xigmatek S1283.
I have a TRUE with an S-Flex SFF21 fan. Big, works well. I'm using it with an EP35-DS3P and a Q6600 OC'd to 3.6 GHz. The motherboard has enough clearance that I can orient it horizontally or vertically. I have mine oriented vertically to take advantage of the 20 cm fan in the top of my Antec 900 case.
However, if I were buying an HSF today, I'd look at the Xigmatek S1283.
------------------------------ Overclocking since 1978: TRS-80, 1.77 MHz Z80 to 2.01 MHz.
Reply to jsc
There are 1290 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
