Hey im a total noob to overclocking. Im trying to overclock my e6400 duo processor on a p95 neo motherboard. I go into bios the FSB has a minimum of 266 and a maximum of 333. Do any of you guys know why theres a maximum FSB in the bios? anyway when i change it to 333 and reboot the system starts fine but actually only runs at 666 mhz since the multiplier changes from x8 to x2. On the other hand in CPUz it says that its running at 2000 mhz and at times moves up to 2800 mhz with the voltage fluctuating wildly. Any help.
------------------------------Which Chip? Well, it depends on which set of thieving b@stardz you choose to support: The ones who use insider trading to enrich themselves while running their company into the ground, or the ones who illegally pay vendors to not support the first group.
Reply to Scotteq
Ok thats great. So it means i actually overclocked it to 333 mhz. But on the other hand is this the maximum for the cpu or the maximum for the motherboard? the motherboard wont let me select a value larger than this. Any way to get around it?
You really need to read some of the stickies on this site. Many of the answers you are looking for are explained really well in them. Do a little work, there's more to OCing than just changing your FSB...
------------------------------Antec Nine Hundred, Gigabyte P35-DS3R, Intel Q6600 @ 3.2 Ghz, Thermalright Ultra-120 Extreme, eVGA 8800GT 512MB, G-Skill 4GB (2x2GB) DDR2-800 4-4-4-10, Seasonic S12 ATX 650W, Seagate Barracuda 7200.10 320GB SATA, 26" LCD Monitor (1900x1200), Windows XP Pr
Reply to deuce271
