Tom's Hardware > Forum > Overclocking > General Discussions > The Toms Hardware $500 PC overclocking help
Forum Overclocking : General Discussions - The Toms Hardware $500 PC overclocking help
Hey peeps. First time post. I purchased all of these parts because it was getting good feedback.
I need some step by step instructions on how to overclock the $500 PC build that was set up at the following:
http://www.tomshardware.com/review [...] ,1907.html
I am still waiting for a few bits but how do I overclock everything?
Is there a walk through where I can use the same settings in the review? It does say it changed x to y etc but I need to know where do I go etc to make these changes? I am new to overclocking and need to make sure I am changing the correct values.
Do I need any extra software or is everything I need to change in the bios?
Thanks! :love:
Sponsored Links
Is it the AMD or the Intel?
You just need to change the bios.
For Intel:
http://www.tomshardware.com/forum/ [...] uals-guide
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
It is an intel. Thanks for the link.
http://media.bestofmicro.com/W/S/98380/original/500pc_pricelist.png
Reply to thefyn
http://www.tomshardware.com/forum/ [...] dated-2008
This is a very detailed, step by step guide for that board and chip. I have the same setup and am currently at 8x400 for 3.2ghz.
Reply to rfatcheric
awesome thanks
Reply to thefyn
All the parts came and I put it together last night.
Since you have the board, can you tell me what I need to change?
I am getting a little lost in the woods of info.
I just need to know change XXX to YYY when in the bios.
Thanks!
Reply to thefyn
every system OC differentlt.just dont expect someone does it on XXX and you can do it on XXX as well.that is the rule of OC. you need to up each setting one by one then boost voltage to go further.
Reply to iluvgillgill
Or put the voltage to a certain point and OC as far as you can :D
------------------------------ Na na na na na na na na HATMAN!
Reply to Hatman
yeah that work as well:) look out for load temp though:P
Message edited by iluvgillgill on 06-22-2008 at 03:17:37 PM
Fail.
PC wont power up.
I changed the multi to 8/400 giving me a core of 3.2
I changed the voltage to 1.45
One thing I didn't understand. It said to change the ddr cas 5-44-10. how do i go about doing that?
I reset the bios but am wary about doing it again. What would make the PC auto shut down? At normal temp my CPU is 30 degrees. The cooler rocks balls. I think I am missing one or 2 obvious changes that allows the whole thing to work. Is there anything obvious I need to change in order for the PC tp work with the new CPU core change?
Reply to thefyn
change the timing of the ram to 5-5-5-18 for now and leave the voltage on 2V. since im not there to test it out. can you list the vcore displayed in CPU-Z in windows for both IDLE + FULL LOAD.
Okay I will try it. Will it be obvious in the bios where I change the ram timing to 5-5-5-18
I could not see where I could change values. I am in work now.
Reply to thefyn
since you dont know where to do what its better to take picture of your actual BIOS OC menu.
This is a Gigabyte motherboard, so you'll have to hit Ctrl F1 in the BIOS menu to access such options.
------------------------------ "Nvidia, the Way It's Meant to be PAID Played! - Corrado
*Lesbian Lover Club* - founder Assman
Reply to Evilonigiri
Awesome. Thanks.
Reply to thefyn
I get three long beeps. I can't take a pic of my screen.
Reply to thefyn
Update:
I can only up the CPU to 2.4
Here are some pics of CPUID what I am seeing:
http://www.web-design100.com/untitled.jpg
http://www.web-design100.com/untitl4ed.jpg
Why would the PC shut down? I do have a different type of memory. Do I have to change the memory values? And what do I change them to?
Message edited by thefyn on 06-30-2008 at 07:37:59 PM
Reply to thefyn
does your pc shut down completely when you turn it on or it turns on then off in like 2 sec then will come on?
Once I save settings and exit bios it shuts down immediatley.
Then starts back up, waits for a few seconds, then shuts down again. It does this three times before starting again with the fail safe defaults.
I think it must me a gigabyte built in stability routine.
Reply to thefyn
that means your mobo dont like the OC on your CPU. its called the "twice reboot".
try to fine tune the OC setting. thats the only way to solution.sorry!
(Shakes my fist to the TH $500 over clocked PC article)
LIES! !!!! LIIIIEEESSS!!!!
haha
Reply to thefyn
you really need to fine tune the setting.spend your whole weekend is a good idea. i OC a gigabyte 650i before. even the OC is prime stable for 24hrs. but the bios doesnt like it when boot up from cold. but if i do restart in windows the OC will stay. but when its been shut down completely, once i turn it on again after the "twice reboot" it will reset the OC to stock. then by then i press reset on the case it will restart with my OC. its ok with a warm reboot not cold.:)
I spent around 2 hours edging everything forward, trying different multiplers etc etc. I did manage a boot at 2.5 however when it got into Windows land it froze.
I'll try the warm reboot. Thanks for all of your helpage.
Reply to thefyn
To OP. Just making sure. You have the P35-DS3L and not the EP35-DS3L, right?
Reply to flyin15sec
Yarp. It is the P35-DS3L
Reply to thefyn
UPDATE: Looking good now. I am up to 3ghz. Looks like the memory was the issue and I had to scale that down a timing wise. It does boot at 3.2 however Windows crashes. BUT I WILL TAKE IT! :-)
Reply to thefyn
andyro0 wrote :
wats the difference?
the difference is the E in the new model means Eco. so the new model is greener.
oh and some fancy LED on the mobo as well!:D bling factor?!?!
Awwww...I was going so well:
So I manage to get it up to 3,2 ghz and it seemed okay
I ran a burn in benchmark and walked away. The temp when I left it was 55 degrees after an hour of 100% CPU activity. I went and watched a movie, came back to a nice blue screen of death.
I switched the PC off. Waited for it to cool, and noticed it still booted at 3.2ghz CPU etc etc.
HOWEVER, when I opened up CPUZ it said I was running at HALF speed 1.6. The MOST I can now get out of my PC is the standard 1.8ghz, the standard spec for the CPU. No matter what I change in the Bios, it will NOT overclock.
So it looks like the settings I place in the bios are being overidden somewhere. What happened? Any ideas?
When I reboot and go into the bios the overclocked values I initially entered are still there. But when I boot into windows land the CPUZ tells me I am not overclocked.
Reply to thefyn
is speedstep or cle turned off?
Reply to Shadowthor
^Agreed. You need to disable EIST/SpeedStep.
My settings for E2180 @3.2Ghz:
http://farm3.static.flickr.com/2317/2559132573_18fe90f557_b.jpg
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
4800th Post! W00t!
Stupid question. How do I disable it? I can't find it. I have skills yo
Reply to thefyn
I did install PC booster. Could this have changed a setting to overide my bios settings?
I uninstalled it however still my settings are not sticking. REALLY frustrating.
Reply to thefyn
I changed the power settings to always on..Still...the values reflected in the bios do not make it to windows...
I am a2 1.2 ffs nooooooooooooooooooooooooooooo!!!!!
Reply to thefyn
wow that's a decent computer for 500~ bucks.
Reply to johoz
Not for me it aint :-)
1.8 ghz ftl
Reply to thefyn
OP: Check the manual on how to disable SpeedStep and EIST.
I disabled both. Still, when I get into windows, it shows 1.2 ghz
I think I will say F it and reinstall windows. Every time I boot into the bios my overclocked settings are there and in place because the CPU is a little hotter than usual. As soon as I get into windows the CPUID tells me I am running at 1.2 ghtz and it peaks at 1.8 on heavy loads.
DRIVING
ME
MAD
Reply to thefyn
Looks like the BIOS settings aren't sticking. Btw, do you have a EP35-DS3L?
No it is the P35-DS3L
Reply to thefyn
The bios settings stick (like when I disable the on board sound etc. Only anything over clocking will not stick.
I did get a blue screen of death after load testing it at 3,2 ghz at 100% CPU load. This was after 2 hours.
Could I have broken something?
Reply to thefyn
Try 3Ghz and see. Also list:
VID
CPU Temp with Prime95 Small FFT
Full voltage settings (ie CPU voltage, GMCH voltage,RAM,etc)
VID
I did. I also tried it at 2ghz and it took me down to 1.2 with 1.6 load max.
Reply to thefyn
VID
Off the top of my head cpu voltage was 1.5ish ddr 2 etc etc was .2 over.
Reply to thefyn
I also tried various voltage settings (without going to far in the red) and the same result.
Reply to thefyn
Previous
1 2
There are 947 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
