News
Tom's Hardware: GeIL DDR2 test samples faster than commercial devices
Published on April 12, 2006
The first pair of DDR2 modules has completed its test track in the latest edition of Tom's Hardware's Stress Test series. Read more
MicroSD platform faces issues when moving to higher densities
Published on December 29, 2005
With major handset vendor Motorola aggressively adopting MicroSD cards for its handsets, memory card makers see potential in the market segment. Read more
Infineon to manufacture GDDR3 memory for standalone graphic cards
Published on November 19, 2004
Infineon extends its memory product line with 256 Mbit Graphic Double Data Rate 3 (GDDR3) Synchronous Graphics RAM (SGRAM). The company believes its memory will allow higher resolution, lifelike realization and more details in applications such as 3D graphics and games. Read more
OCZ sees more room in DDR1 speed, clocks memory at 772 MHz
Published on February 24, 2005
OCZ Technology today said it has built a dual-channel DDR1-772 memory with 3-4-4 timings. Read more
Latest Reviews & Articles
Tom's SBM: The $1,500 Mainstream PC
Published on October 29, 2008
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
System Builder Marathon: The $4,500 Super PC
Published on October 28, 2008
This month's System Builder Marathon spreads the system prices out even further to $4,500, $1,500, and $500. Is today’s $4,500 system really worth three times as much as an upper-mainstream performance machine? Read more
Can Your Old Athlon 64 Still Game?
Published on October 24, 2008
We'd all love to upgrade every time a new piece of gaming hardware drops, but that's an expensive proposition. You think your Athlon 64 system is fairly quick--any chance a simple graphics upgrade can bring it up speed? We're aiming to find out. Read more
Benchmarking With Intel's NAS Toolkit
Published on October 23, 2008
We've been publishing our networked storage stories using Intel's NAS Performance tool kit as our primary benchmark. But before we went any further, we thought we'd introduce the software package and its individual components. Read more
  Tom's Hardware Forums » Overclocking » AMD » Higher memory speed or higher CPU speed?
Word :   Username :
Bottom
Author
 Thread : Higher memory speed or higher CPU speed?
Profile: stranger
More Information
Hello,
I've decided to OC my 4800+ (socket AM2) a bit more today, to 3GHz to be precisely.
Now I've got two situations:
Run my CPU at 11.5x250=2850MHz with my RAM at ~411MHz 4-4-4-12 2T (haven't tried 1T at this speed yet)
Run my CPU at 12x250=3000MHz with my RAM at ~375MHZ 4-4-4-12 1T
My RAM is OCZ Platinum Revision 2 @ 2.00V
Is it better to have situation 1: Slower CPU, faster RAM, or 2, exactly the opposite.
Thanks in advance,
-iDont
Related Product
Profile: nimble knuckle
More Information
I dont think you are going notice any difference either way....
I would go with the 3000mhz CPU.
Gigabyte X48-DQ6 / Q9550 @ 3.4ghz (400*8.5) / VisionTek 4870x2 / 4GB Mushkin 1066MHZ (2*2) / Xigmatek HDT-S1283 / Antec TruePower Quattro 1000 Watt (Quad crossfire one day) / Samsung 22x DVDRW Lightscribe / Two 500GB Seagate 7200.11(raid 0)
Profile: stranger
More Information
Thanks for your reply.
If the speed is about the same in both situations, isn't it better to go with the 2850Mhz then? Because I guess the CPU lives longer then and the RAM can take 11MHz on top of its stock speed with no problem :P
-iDont
More Information
In my opinion a mild OC is better then an aggressive one. Nice to have the rig last for a while.
If the machine is on its last legs or a plan to buy a new machine is in place ill OC till it cant be OC'd anymore and run it like that 24/7. When its your daily use machine and you dont want to buy another anytime soon mild OC is the way to go.
Of course this is only one mans opinion.
Profile: newbie
More Information
If your temps on the CPU/mobo are within operating specs, there will be no longevity loss on your components.
The best overclock is the highest you can get both your CPU and RAM to run at, while being stable. The difference between 1T and 2T is barely noticeable, typically less than 3 nanoseconds.
What I would recommend is downloading Everest Ultimate, and using the benchmarks within to justify which way you will run your system. Although they are only numbers, they are usually indicative of how the system will perform in real life applications.
Google Ads
