Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Can I run this video card with this wimpy power supply?
Forum Graphic & Displays : Graphics Cards - Can I run this video card with this wimpy power supply?
I was thinking of upgrading my Nvidia Geforce 6600 to a 7600 GT... however my Dell only came with a wimpy 250 watt power supply so I dont think its going to work without getting a better PSU. Im sure you might wonder why I dont purchase a better PCI card instead of this AGP based card.... well my old ass motherboard does not support PCI express graphic cards :pfff:
Thanks
Sponsored Links
I used to do stuff like that and never had a problem. If that card is PCIE does it require a power connection? I had to ditch my old Gateway PS because of a video card power requirement.
Reply to Ace_437
- 0 +
The PCIe version of the 7600GT does not require auxilliary power. That PSU is miniscule, but might be enough. How many amps on its +12V rail?
I had a PC with a X2 3800+, 2GB of RAM, 2 HDDs, and a 7600GT in it that only pulled 126W out of my UPS when idle.
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
- 0 +
It depends on how well your PSu has lasted over the years. They do tend to lose capacity in time. Go ahead and try. At worst you'll have to buy a StealthXStream 600 or some other cheap but decent PSU that actually fits in Dell boxes.
Make sure the 7600GT you buy has DDR3. not DDR2. The DDR2 version is much slower.
Reply to aevm
- 0 +
As long as your psu isn't ancient it will work fine. That's the limit on the Dell 250w though.
------------------------------ P35-DS3L Rev 2 bios F9C l E8400 @ 3.6Ghz @ 1.232v l OCZ Vendetta 2 /LGA775 Bolt-Thru l 4GB G.Skill 8800PI@1000mhz 4:5 @ 1.87v l WD3200AAKS 320GB l Evga 8800GTS 512 l X-Fi Xtreme Music l Corsair HX520 l Antec Sonata III 500 l Vista32 SP2 l Win7 X64 7600
Reply to kpo6969
Ok lets say I do purchase this card my next question is will I see a big difference in video performance over my Geforce 6600 card? My current system specs are as follows -
Manufacturer : Dell Computer Corporation (Model Dell DIMENSION DIM4600)
Mainboard : Dell Computer Corp. 02Y832
Chipset : Intel i865PE
Processor : Intel Pentium 4 @ 2800 MHz
Physical Memory : 2048 MB (4 x 512 DDR-SDRAM )
Video Card : Nvidia Corp GeForce 6600 [NV43]
Hard Disk : WDC (120 GB)
DVD-Rom Drive : LITE-ON DVDRW SOHW-1693S
CD-Rom Drive : Lite-On LTN486S 48x Max
Monitor Type : NEC Technologies NEC FE991SB - 18 inches
Network Card : Broadcom Corp BCM5705 NetXtreme Gigabit Ethernet
Network Card : Intel Corporation PRO/100 VE Network Connection
Operating System : Microsoft Windows XP Home Edition 5.01.2600 Service Pack 2
DirectX : Version 9.0c (December 2007)
Reply to madhatter4
- 0 +
Assuming your video card is an AGP card. I suggest upgrading the PSU and getting an HD2600XT like the following.
http://www.newegg.com/Product/Prod [...] _-14161207
Here are some other options for the video card
http://www.newegg.com/Product/Prod [...] name=512MB
Message edited by jerryc on 01-04-2008 at 12:10:15 AM
Reply to jerryc
^^^Actually I dont want to purchase a whole new PSU and all that. Im going to replace this entire PC in a year so I was kinda hoping you people could suggest a good AGP video card around $100 that would work with my system. This would be the absolute last upgrade I ever do to this system... :non:
Thanks
Message edited by madhatter4 on 01-04-2008 at 12:33:40 AM
Reply to madhatter4
There are 1146 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
