Solved
Outlook 2003 Problems
I was using Outlook Express in XP before I changed to Windows 7 just now. Now I have to use Outlook 2003 which I have. Everything was installed but outlook doesn't send or receive email. It's sending "forever". I checked the server names, and everything else, but it's not doing anything. Any help would be appreciated.
1 answer Last reply Best Answer
More about outlook 2003 problems
  1. Best answer
    Make sure the ports are correct for the connection. If the connection to the server is over SSL or TLS, the port(s) used for the connection may be different.
Outlook 2003 Outlook Express Windows XP Windows 7
