News
CeBIT 2008: RAM Watercooling By Gigabyte
Published on March 05, 2008
Gigabyte, more commonly known for its motherboards and graphics cards, is presenting a water cooling solution for RAM modules, dubbed Cool Rain. Read more
IBM promises cooler chips with capillary-action and water jets
Published on October 27, 2006
IBM's Zurich labs have developed a new heatsink and water-cooling that promises to cool chips up to six times better than conventional air cooling. The heatsink contains tiny channels similar to the capillaries you would see in tree leaves and in human circulator systems. The channels allow either water or heatsink compound to spread more uniformly and thereby dissipate more heat. Read more
Corsair intros water cooling kit
Published on January 28, 2005
Memory company Corsair announced a water cooling kit. Read more
IBM Cools 3D Chips With Integrated Water Channels
Published on June 05, 2008
Zurich (Switzerland) - Why cool semiconductors with liquid on the surface when you can run water right through them? Read more
Latest Reviews & Articles
System Builder Marathon: $500 Gaming PC
Published on October 30, 2008
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
Tom's SBM: The $1,500 Mainstream PC
Published on October 29, 2008
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
System Builder Marathon: The $4,500 Super PC
Published on October 28, 2008
This month's System Builder Marathon spreads the system prices out even further to $4,500, $1,500, and $500. Is today’s $4,500 system really worth three times as much as an upper-mainstream performance machine? Read more
Can Your Old Athlon 64 Still Game?
Published on October 24, 2008
We'd all love to upgrade every time a new piece of gaming hardware drops, but that's an expensive proposition. You think your Athlon 64 system is fairly quick--any chance a simple graphics upgrade can bring it up speed? We're aiming to find out. Read more
Water Cool Leak!!
Word :   Username :
Bottom
Author
 Thread : Water Cool Leak!!
You Cant Stop The Revolution!
Profile: newbie
More Information
Hey Guys
I have a leak in my Zalman zmWb3 Gold water block..its leaking from the...the nozzle where it screws into the actual water block..There the black plastic ones versus the metal nut ones.. This is the second time' any ideas on how to stop it from leaking.. The Pump is an External Pump that sits in the Resivor its self..and pumps at 130GHP ....I also have this cooling my 8800GTS..with no problems on that block just the zalman'
Right now im back to the Intel Heat Sink..running at 48 -44 on all four cores to Hot seems about right to me?
Related Product
Master-de-bater
Profile: Eternal Poster
More Information
That's partly why I stick with air-cooling. But that aside, you're suppose to test the water cooler without the components first to check for leaks. You know, run it for a day or so to make sure it isn't leaking.
I suppose you could use those white, water-proof seal tapes along with duct tape to seal it.
"Nvidia, the Way It's Meant to be PAID Played! - Corrado
*Lesbian Lover Club* - founder Assman
Profile: newbie
More Information
I did actually the system been running for about 3 months when this leak appeard today same spot the last time it leakd... only reason i cheakd is becuase i smelld coolant lol
Profile: old hand
More Information
Have you checked to see if it's the nylon barbs that have the crack, or if the block has cracks or wear around the barb openings? If it is the latter, bad news. Crack in block = bad. Perhaps you have a bad o-ring in there?
Nylon barbs are supposed to be better at sealing the threads as opposed to brass barbs, but can also crack at their seams, if they have them. This is to eliminate the need for teflon tape, but also increases the possiblity cracking will occur. Plastic barbs are OK, but I stay away from the black plastic ones...they are usually junky. I head to the hardware store and pick up the nylon plumbing ones.
The Pastafarian belief of heaven stresses that it contains beer volcanoes and a stripper factory. Hell is oddly similar, except that the beer is stale, and the strippers have VD
Profile: member
More Information
Stripped threads maybe? Could try new barbs to see if that works,but if its a cracked block than its fire in the garbage and grab another one.
Profile: member
More Information
ok here we go-
first drain the system and remove the block. On a clean work surface dismantle it and get a nagnifying glas and inspect all the parts for crack or other issues, inspect the orings for flats and twists. Replace and bad parts and reassemble and move on. If block is cracked get a new one, attempting to patch cracks in any of the parts will be short term and will leak again. And just in case make dam sure you are using DI water....it is not conductive...ensuring no sparkysparky if you get more leaks.....amd also....spend a few more bucks as you replace parts and get the stainless stuff.....it is significantly better.
good luck
QX6700- asusP5BE- corsair xms2-4G- EVGA 8800GTS 640- audigy SE- zboard merc- samsung 931c syncmaster-
Profile: nimble knuckle
More Information
Whenever you have to use screw-in fittings for anything in a cooling loop it is advisable to use either teflon tape or "plumbers goop" around the threads. Each product creates a seal as you "screw in" the fitting, thereby compensating for any potential leak. However, I recommend using both (which is what I do on all my fittings) by taping the teflon tape around the threads and then wiping a thin film of "plumbers goop" over the taped area. Plumbers goop will help create a seal around the threads (helping the teflon tape) and it will form a seal at the base of the fitting as well. You can find teflon tape or plumbers goop at any hardware store like Home Depot or Lowes. While plumbers goop will aid in sealing any gaps in the threads it only forms a rubbery consistency when dried so you needn't worry about any permanent bonding.
Message edited by phreejak on 06-14-2008 at 12:49:38 AM
Swiftech Mcres-Micro Reservoir, MCP655 Pump, D-tek Fuzion CPU Waterblock w/nozzle kit, Thermaltake Toughpower 1200, Swiftech Stealth GPU Waterblock, 2 external dual 120mm rads (each with four 120mm fans in "push-pull" )
Profile: newbie
More Information
Thanks Guys ill try te plumber Goop and Teflon tape..and c if that does the trick
U win some, the rest u smoke
Profile: old hand
More Information
My water sys has leaked HEAPS of times in the beginning.
For your situation: plumbers tape around the thread SHOULD cure it. If not maybe some plumbers pvc glue as a more permanent measure.
Other tips:
1: Better hose. Tygon is the BEST stuff around. Also use metal hose clamps, not too tight tho.
2: Ditch anything with the name Zalman on it. Im pretty sure they use alu stuff. Use an ALL COPPER system. Alu and copper react.
3: Use anti corrosive/conductive fluid/additives. Duh.
Q6600 B3 3.0Ghz @ 1.125v load
4850
P5B-D
8Gb 800mhz
Profile: addict
More Information
Get rid of those plastic and nylon fittings, stick with metal fittings with compression locks. Stay away from plumbers goop, you don't want it getting into the cooling system stick with teflon tape.
Profile: addict
More Information
call a plumber, have him fix the leak. or visit your closest home depot store for help.
Message edited by godless on 06-14-2008 at 03:51:48 AM
Phenom 9500 @2.5ghz|MSI K9A2 Platinum|500Gb,750Gb Seagate 7200.11|2Gb OCZ Ram|Diamond HD3870 @850Mhz|CM 690|OCZ 700Watt
Profile: member
More Information
i am a fan of plumbers tape. use it on the threads, it works wonders.
Google Ads
