I just recovered my XP SP3 from a system error that involvrd an infinfite reboot loop. Fixed using a windows 7 cd check disk system.
Anyway after that my computer started up fine and worked but then wierd problems started to happen.
Sound doesnt work at all (from speakers to USB headset.) even though its detected in control panel>sound and audio devices. Nothing on sound appears in the system tray, I can't change the sound from control panel because its all greyed out.
Second thing, no active software appears on the taskbar. And when you minimize it, the only way to bring it back is to alt+tab it or go on control panel and click switch to. Ive tried the kelly's korner fix but all that did was make them minimized under the task bar so they were just a tiny cube with the three exit, minimize and maximize and the restore button. It just doesnt want to be fixed.
Third thing when I right click on something, I can click copy cut and all that. But when I right click elsewhere, paste is greyed out. Even when I select and rightclick-drag, the menu doesnt pop up.
I don't have any XP system cd to reinstall from, but I do have a windows 7 ultimate cd but I would prefer to keep this computer as XP.
Regards,
Hasan
Regards,
Hasan
