Tom's Hardware Forums » Motherboards & Memory » General Motherboard » need help! weird problem
Add a reply
 Word :   Username :
Bottom
Author
 Thread : need help! weird problem
Profile: stranger
More Information
hi i just put my new pc together consisting of a new 160gb sata, gigabyte p35, e6750. 4gb ddr2 800. and a evga 8800gt. i hooked everything up without a hitch i thought and i was successfully able to install vista but now i start up my pc and though i can see it boot up vista it becomes a black screen after im in on my lcd and on my crt the screen starts flickering and readjusting? But when i manually shut my pc down while its doing that the screen becomes normal again and i can see the boot down? please help thanks
Related Pr oduct
Profile: journeyman
More Information
have u tried with only one screen?
Profile: stranger
More Information
yes ive only tried 1 screen. i only tried my lcd because my crt wasnt working so i figured out that the problem wasnt with the screen. so its something with the pc.
Profile: stranger
More Information
Can you get into SAFE mode? You're refresh rate might be too high. Happened to me once.
Profile: stranger
More Information
i can get it into safe mode. my refresh rate cant be changed though. its set at like default settings and i cant change it.
Profile: stranger
More Information
i installed the drivers from the disk the card came from which didnt work so i tried to download the newest ones from the web with safemode+networking but im unable to install them? vista wont let me it says unable to locate folders or something i think it has to do with safe mode restrictions? also i havent been able to install my mobo drivers because its not working from the disk in safe mode? i also tried my old 7600gt and switching the memory slots to 2 and 4 instead of 1 and 3. all has not worked. im so frustrated ha :/
Profile: nimble knuckle
More Information
Maybe pop back into safe mode, and get into your video card drivers, see if it will let you install a generic vga driver just so you can get into windows, screen might look kinda bad, then download and install nvidia drivers from nvidia, or get newer ones via windows update.
More Information
Just thinking another option might be to do this....On vista for me, it detects my 7300 just fine, and loads it's own drivers. So maybe do this way. Load up the 7600 gt, boot from cd, and let vista install all drivers itself. After you get it up and running, download nvidia drivers from nvidia's website, uninstall the 7600 gt in device manager, power down, take the card out, and install your newer card, reboot, let vista detect it. DO NOT install the drivers from that cd, but maybe chuck that cd in the garbage....lol. Anyway, let vista pick up the new card itself as best it can, then install the nvidia drivers, perform all updates, etc...hopefully your system will run fine.
Also, why do you have memory in slots 2 & 4 or 1 & 3? Why not side by side in 1 & 2?
Message edited by ohiou_grad _06 on 01-30-2008 at 03:59:44 AM
Add a reply
Google Ads
