Yes No
Ads
Tom's Hardware > Forum > Overclocking > Heatsinks & Air Cooling > Homemade water cooling Case (DIY Fan Controller)
Forum Overclocking : Heatsinks & Air Cooling Homemade water cooling Case (DIY Fan Controller)
Page:    Previous 1 2 3 4 5 Next Bottom Search this thread
My home made Transparent Case with home made Water Cooling
http://img294.imageshack.us/img294/2018/systemlq6.jpg
http://img294.imageshack.us/img294/3038/blockno6.jpg
Please tell your comments about it.
Thanks
Rakesh Sharam
MY PC:-
AMD Athlon X2 4000+
ASUS M2N-E
2-GB DDR2 667
160-250-400 GB Sata HDD
MSI ATI R3450 256MB DDR2 Graphice
Creative 7.1 Audigy Value
Philips TV-Tuner
Message edited by rakesh_sharma23 on 08-24-2009 at 07:04:02 AM
Reply to rakesh_sharma23
Does it leak? :na:
So, what parts did you use to make it?
------------------------------ Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Reply to dagger
No it dont leaked. I have tested it for more than 48hous cont.
Metal:- Aluminum Northbrige heat sink with acrylic sheet.
Working fine
Thanks for your reply.
- 0 +
Thanks for the link on the other thread, I was super confused. Looks nice, good job! Huge tubes!
------------------------------ EVGA nForce 680i SE SLI 122-CK-NF63 Motherboard - Intel Core 2 Duo E6600 @ 3.2 GHz - ZALMAN 9500A 92mm CPU Cooler - EVGA 8800GTS 512MB OC 766/2000 - G.SKILL 6GB DDR2 800 4-4-4-12 (2T) - Thermaltake Purepower 600W Power Supply - Vista Ultimate x64
Reply to lcaley
More Pic of my pc
NIGHT MODE:-
http://img381.imageshack.us/img381/8341/img0152ky8.jpg
FRONT VIEW:-
http://img176.imageshack.us/img176/5100/img0146nm8.jpg
Looks like a lot of work. Thumbs up for pulling that off.
Reply to Slobogob
- 0 +
I dont like a whole lot of transparent stuff, but you made it work very well :) Nice job, and congrats with the success of your home brew water cooling.
------------------------------ macgirlfriend:
"Hey I don't get you people, the people on insanely mac were so much nicer"
Reply to skittle
Thanks here are few more pics
http://img135.imageshack.us/img135/9918/img0160yz9.jpg
http://img382.imageshack.us/img382/4507/img0158ej3.jpg
thanks " Mr. skittle"
- 0 +
What about temperatures? How well does it cool?
Reply to dagger
The temps can't be that bad. After all, it looks SICK! Something I would probably never be able to do.
------------------------------ "Nvidia, the Way It's Meant to be PAID Played! - Corrado
*Lesbian Lover Club* - founder Assman
Reply to Evilonigiri
I can't see the heat exchanger very well..can you show me some of that?
Is there a reseviour at all?
Good work, btw
Reply to frozenlead
where is da radiator?i can see them or it?
Reply to iluvgillgill
Nice work. What temps are you getting and were the water blocks CNC milled and lapped?
------------------------------ http://farm5.static.flickr.com/4113/5052517574_1d0ebc741b.jpg
Reply to Shadow703793
nice work!
------------------------------ http://i33.tinypic.com/sw3a5y.png
http://tinyurl.com/yfmxdc9 - Part Guide? http://tinyurl.com/5zk6me - VGA power?
http://tinyurl.com/5v55wk - C2 Mem performance? http://tinyurl.com/6pmbke - SLI/Xfire?
http://tinyurl.com/yjldsrw - No Boot?
Reply to nukemaster
Thanks to all
As about temp of CPU
AMD Athlon X2 4000+ @ 2.1Ghz overclocked at 2.9Ghz
Normal temp = 31 C
On Ex-load for 2 hours Temp =40 C
Room Temp = 35 C
Here is the pic of my radiator & home made pump, Full coper Radiator is from old Oil cooled Machinary from local scrap yard.
No reseviour used, since my radiator can hold 675ml of coolent.
http://img293.imageshack.us/img293/3997/img0159fb4.jpg
http://img293.imageshack.us/img293/8041/img0154jv0.jpg
I always love custom jobs as I sometimes custom make my own waterblocks.
Good job.
One thing though, am I correct in that you are using a modified aluminum heatsink in your custom CPU waterblock? If so, are you not concerned with galvanic corrosion since you are using a copper rad?
------------------------------ Swiftech Mcres-Micro Reservoir, MCP655 Pump, D-tek Fuzion CPU Waterblock w/nozzle kit, Thermaltake Toughpower 1200, Swiftech Stealth GPU Waterblock, 2 external dual 120mm rads (each with four 120mm fans in "push-pull" )
Reply to phreejak
My aluiminium heatsink is having "Silver Flash" coating on it. I am using Non-modified MB-Chipset Heatsink. And accouding to Galvnic table and all galvanic corrosion calculations on these two metals results in a lifetime period of more then 70 years.
long time..................So no worry of galvanic corrosion.
VERY GOOD RESEARCH!!! I am impressed! Nice clean install on it too!!!
------------------------------ I suffer from A.D.O.S.
Attention Deficit..... OOOOOOH!!! SHINY!!!
+5 Victim
Reply to Groveling_Wyrm
Thanks Mr. Groveling
- 0 +
sweet job.
digging the stickers =p
Reply to akind
Nice...I just finished a set up with an copper racing oil cooler and some clear acrylic radiators. I'll try to get some pics up this weekend after I remount the waterblock on my new 9800gtx.
Message edited by rubix_1011 on 06-27-2008 at 03:46:29 AM
------------------------------ Watercooling Info:
Tom's Hardware Watercooling Sticky
Build Log | Project: Askew
Stuff 4 Sale
Reply to rubix_1011
what kind of pump did you use?
Reply to espslyxerx2
Asking me, or the OP?
Stuff 4 Sale
Reply to rubix_1011
The guy that posted the pics.
WOW!!!! That is incredible! I think you must be some sort of genius to design and build something like this!! Not only am i impressed with the cooler, the entire case is a beauty.
- Hypnotico
Reply to hypnotico
Thanks to all.
AS per espslyxerx2's Question , My pump is made from old printer head motor (HP-640 inkjet) and some plastic molded pumping unit.
Since in small town like my, it's hard to kind a DC PUMP. so i made it my self. I can pump 20 liters of water in 53 sec. at 12v dc.
I am quite impressed with the ingenuity. Good Job.
^Also very impressed with the creativity and execution on this. Great ability to use alternate parts instead of buying retail 'box' components. Thumbs up!
Stuff 4 Sale
Reply to rubix_1011
Room temp of 35 C???
And a load of only 40 C in that kind of ambient T??
Insane.
Reply to quaduser
Mr. Quaduser can you explain why are you asking.
If your asking about room temperature. I live in Jodhpur, India ,its a hot place average room temp is around 35C. Since i am not having any type of room cooling. Just a room fan. That's it .
So my pc use to run at very high temp at normal box pack Cpu heatsink and fan, about 65c at normal running.
This high temp inspired me to do some thing...and you all can see what i came to.
Thanks
i think he means you only gain 5C increase at load he is surprised!!!:D
OO i see.
Thanks Mr. iluvgillgill
- 0 +
Man this is awsome, i wish i had the enginuity and skills to make something like this. I love it how u made this from and old raidiaor, printer moter and heatsink, which probably cost you next to nothing; and yet it works as well if not better than something you would pay £150 for! Nice Job
Reply to pingu12
although it looks a bit messy, i admire your creativity, great job!
maybe ill be on your level one day
i just compared your pump to several market pumps, and i have to say im impressed!!
http://www.frozencpu.com/products/ [...] 30c107s155
thats approx. 20L (320gph=1211.332Lph) per min for $80, compared to yours which is free! lol great job
Message edited by eklipz330 on 08-01-2008 at 12:20:33 AM
Reply to eklipz330
- 0 +
hmm not a fan of the acrylic cases sry :( still nice watercooling!!
Reply to V3NOM
thanks To Mr. pingu 12, Mr. eklipz330 and V3NOM .
Well i am planning to update my water cooling kit to CPU and CHIPSET water block made from copper plates i recently got from scrape.
Time problem... Works as web-developer. Only after job hours for my pc, But Hope to update soon and post new pics soon...
Thanks to all
- 0 +
lol that was a long response XD looking forward to new pics :P
Reply to V3NOM
Here are new updated pic of my rig. With new full copper homemade cpu water block and motherboard water block. with some cable management of fan cable . And side panal fan and power connector brackets.
hope you like it.
http://img375.imageshack.us/img375/1703/img0320ki6.jpg
http://img389.imageshack.us/img389/8615/img0321hz2.jpg
http://img260.imageshack.us/img260/2608/img0322ce1.jpg
http://img401.imageshack.us/img401/5513/img0323mx8.jpg
http://img260.imageshack.us/img260/6830/img0324el7.jpg
http://img260.imageshack.us/img260/5545/img0325fr7.jpg
http://img401.imageshack.us/img401/8614/img0326nz2.jpg
http://img389.imageshack.us/img389/5045/img0327db1.jpg
http://img389.imageshack.us/img389/9060/img0329gx3.jpg
http://img401.imageshack.us/img401/5622/img0330qa0.jpg
http://img401.imageshack.us/img401/2083/img0331gw9.jpg
http://img401.imageshack.us/img401/8704/img0334vq3.jpg
http://img401.imageshack.us/img401/4576/img0335hz5.jpg
http://img389.imageshack.us/img389/112/img0336kh4.jpg
http://img401.imageshack.us/img401/3293/img0337oh9.jpg
That side case fan contact plate thingy is slick. no forgetting to plug in the fans for you :p
Message edited by nukemaster on 10-25-2008 at 01:27:43 PM
Reply to nukemaster
- 0 +
hmmm imo if i were in your position i would have made a wooden case with acrylic side panel ^^ just really hate the top and front of acrylic cases. dvd drives r such a turn off lol
Reply to V3NOM
Show message
I will resize my pics soon.
Ok dear Mr. Conumdrum
Nice rig!
One thing I noticed is that the HDD is vertical instead of the usual horizontal setup. Wouldn't that be possibly bad because of the point load it makes on the spindle?
Also, any plans on adding a dust filter for your intake fans to preserve your nice and clear case?
Reply to antiacid
Well HDD positioning don't effects its working or life.
And about dust filter it's a good idea. i will think about it.
anyone using dust filter for intake fans...?
any link for DIY FAN Dust filters
Previous
1 2 3 4 5
There are 1651 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Will this be a good build to overclock 2500k to 5.0GHz?
By DJDeCiBeL, 15 hours ago:
I'm the one that told him that a Silver Arrow will get to 5Ghz, so I'll take the blame...
Best offers
Top experts
