Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > New m/b - old RAM (bus speed)?
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Will DDR SDRAM at 133mhz work in a m/b with bus speed 200mhz ?
There's 2 conflicting opinions I've heard -
1/ the system will be slowed to 133mhz, otherwise work perfectly
2/ The result will be constant BSOD's
Anyone had practical experience, please?
Sponsored Links
It depends *entirely* upon the capabilities/features of the specific
motherboard involved. Some motherboards support the mixing of RAM
speeds, and some don't. Consult the motherboard's manufacturer for a
definitive answer in your specific case.
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
You can have peace. Or you can have freedom. Don't ever count on having
both at once. - RAH
Reply to Anonymous
Your chipset might (or might not!) allow RAM bus to run at a different
speed from the processor bus.
Check your BIOS setting for appropiate bus syncronization feaures - Enable
timing by SDP, or such.
More hints here: http://www.tomshardware.com/howto/20030701/index.html
or google for more.
Michael
"Yabbadoo" <nospam@thank.you> wrote in message
news:LAvEe.15175$Ag3.802@newsfe4-gui.ntli.net...
Reply to Anonymous
My main computer (A7N8X Deluxe ver 2.0) has a 400 mhz bus. My CPU is an
Athlon XP 3200+ (runs at 400 mhz). I have installed 1.5 gig of PC2100
(133/266 speed) RAM. My FSB speed, at the present is 401 mhz as per Everest
HOME Edition.
I have done this because the 512 meg of PC3200 RAM I was using was not
enough for my video editing and, especially, my heavy usage of VirtualPC.
Regards,
Richard Urban
Microsoft MVP Windows Shell/User
Quote from: George Ankner
"If you knew as much as you thought you know,
You would realize that you don't know what you thought you knew!"
Reply to Anonymous
Thanks folks - advice appreciated. Will research further.
Reply to Anonymous
There are 1331 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
