Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > New Graphics Card Problems
Forum Graphics & Displays : Graphics Cards New Graphics Card Problems
Hey Everybody
Today i got my new GPU through the post, my Geforce 8600GT. I put it in my pc and wired everything up. My pc turns on fine, and i can hear the sound of everything loading, even me signing into msn, but my monitor does not seem to respond, it just keeps flashing. The fan goes around on the card so i know that its getting power. What could the problem be?. The only thing i could think of is iam using a vga monitor, and the adapter that comes with it. Is there a certain way that it has go attach?
Thanks a lot
Reply to THEGREATMADMAN
What kind of motherboard?
What was your old Video Card?
Did you unstall your old video drivers before installing the new card?
Reply to jitpublisher
Its an Asus A8M2N-LA, its a HP PC. My old card was a geforce 7500LE. I did not at first but i put the old card back in, uninstalled the driver, it told me to restard so i turned the pc off and put the new card back in. Thanks a lot
^Sorry for my grammer errors by the way, i am using a lappy keyboard and i am not used to it :(
I believe that this board also has on-board graphics...is that correct? Can you plug you monitor into the onboard VGA connector and see if that works?
If what I am thinking has happened, the BIOS may have defaulted back to the integrated on-board graphics when you removed your old video card and drivers. May not be this at all, but at this point that is kinda what I am seeing.
If that does get you a screen on your monitor, you can then get into the BIOS to change/turn-off the onboard graphics, tell it to look at the PCIe slot first, etc.
Hello,
Yes this card does have on board graphics, however HP have removed the interface it seems, and there is just a black cover. I think i already set the default to PCI-E though, i'll quickly double check, thanks a lot mate.
Just to note that with a little damage i manged to remove that black cover. I am now running on internal. I have gone into device manager but i can't see the new card listed. What should i do now? install it with the driver disc?
Thankyou
I would try, if the software cannot detect the card, it won't install. If that don't work, I would do this.
Remove the new GPU, leave your monitor connected to the onboard graphics.
Reboot into Windows.
Shutdown.
Reboot and enter the BIOS.
Set the dsplay to PCIe first, if needed, exit BIOS and shutdown without rebooting into Windows.
Reinstall the new GPU.
Connect the monitor to the new GPU and try again.
If you have a screen with the onboard graphics, I am pretty sure there is indeed a BIOS setting that is not allowing your new PCIe card to initialize first.
There are 1645 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I need a new video card - Help?
By Pinhedd, 1 hour ago:
6670 1GB hands down. The 6570 is less powerful and has inferior GDDR3 RAM which is vastly...
Best offers
Top experts
