Here is my current build. It will be primarily used for gaming, light office work, non professional photo and video editing (just for my own use) and Internet.
I am not comfortable overclocking so most likely will not do it unless I change my mind. Due to not OC'ing, I will use stock CPU cooler for now.
Mobo: Abit IP35 Pro
CPU: Intel Q6600 w/G0
Memory: G.SKILL 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit Desktop Memory
PSU: Corsair 620w HX
Vid: eVGA 8800GTS 512mb (G92)
HDD: Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM SATA 3.0
Optical: Samsung DVD writer (20x) with Lightscribe, SATA
Soundcard: Creative Sound Blaster X-Fi XtremeGamer 7.1 Channels PCI
Media Card Reader: Mitsumi FA404M Black
Case: Antec P182
Questions:
1. Since I don't want to OC, is the E6850 a better choice due to higher clock speed (3.0ghz I think)?
2. Am I better off with memory with faster timings, e.g. CAS4 rather than CAS5? And, do I need 4gb? I'll be running XP Prof until Vista works out its kinks.
3. Is it pretty easy to OC? Should I be doing it?
Thanks
Mobo: Abit IP35 Pro
Case: Antec P182
Questions:
Thanks
