Tom's Hardware Forums » Homebuilt Systems » New System Build » Building a new AMD rig from scratch, PLEASE give input..
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Building a new AMD rig from scratch, PLEASE give input..
Profile: newbie
More Information
Heres my rig...tried to keep a good price/performance ratio...as a college student im kinda broke.
Just making sure there are no conflicts...such as Zalman 9500 cpu cooler interfering with anything..
hopefully someone has ran a similar setup and can let me know if everything goes togethoer well and ample clearances
THANKS...HERE IT IS
    ASUS 18X DVD±R DVD Burner with LightScribe Black PATA Model DRW-1814BL
    ASUS 18X DVD±R DVD Burner with LightScribe Black PATA Model DRW-1814BL - OEM
    Item #: N82E16827135148
    Return Policy: Standard Return Policy
    $28.99
    APEVIA X-CRUISER-BK Black Steel ATX Mid Tower Computer Case
    APEVIA X-CRUISER-BK Black Steel ATX Mid Tower Computer Case - Retail
    Item #: N82E16811144151
 -$15.00 Instant
    $15.00 Mail-in Rebate
    $79.99
    $64.99
    Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive
    Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
    Item #: N82E16822136073
    Return Policy: Limited 30-Day Return Policy
    $104.99
    ASUS M2N32-SLI Deluxe Wireless Edition AM2 NVIDIA nForce 590 SLI MCP ATX AMD Motherboard
    ASUS M2N32-SLI Deluxe Wireless Edition AM2 NVIDIA nForce 590 SLI MCP ATX AMD Motherboard - Retail
    Item #: N82E16813131011
    $169.99
    SAPPHIRE 100226L Radeon HD 3850 512MB 256-bit GDDR3 PCI Express 2.0 HDCP Ready CrossFire Supported Video Card
    SAPPHIRE 100226L Radeon HD 3850 512MB 256-bit GDDR3 PCI Express 2.0 HDCP Ready CrossFire Supported Video Card - Retail
    Item #: N82E16814102715
    $199.99
    APEVIA ATX-CW500WP4 ATX 500W Power Supply
    APEVIA ATX-CW500WP4 ATX 500W Power Supply - Retail
    Item #: N82E16817148027
 -$5.00 Instant
    $39.99
    $34.99
    Logitech X-230 32 watts RMS 2.1 Black Speaker System
    Logitech X-230 32 watts RMS 2.1 Black Speaker System - OEM
    Item #: N82E16836121123
    $38.99
    Microsoft Comfort Curve 2000 B2L-00047 Black USB Ergonomics Keyboard Mouse Included
    Microsoft Comfort Curve 2000 B2L-00047 Black USB Ergonomics Keyboard Mouse Included - OEM
    Item #: N82E16823109156
    $21.99
    Arctic Silver 5 Thermal Compound
    Arctic Silver 5 Thermal Compound - OEM
    Item #: N82E16835100007
    Return Policy: Consumable Items Return Policy
    $5.99
    Rosewill RTK-002 Anti-Static Wrist Strap
    Rosewill RTK-002 Anti-Static Wrist Strap - Retail
    Item #: N82E16899261005
    $5.49
    G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-2GBNQ
    G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-2GBNQ - Retail
    Item #: N82E16820231098
    Return Policy: Memory (Modules, USB) Return Policy
 -$40.00 Instant
    $88.99
    $48.99
    AMD Athlon 64 X2 6000+ Windsor 3.0GHz Socket AM2 125W Dual-Core Processor Model ADX6000IAA6CZ
    AMD Athlon 64 X2 6000+ Windsor 3.0GHz Socket AM2 125W Dual-Core Processor Model ADX6000IAA6CZ - OEM
    Item #: N82E16819103772
    Return Policy: Processors (CPUs) Return Policy
    $139.99
    ZALMAN 9500A 92mm 2 Ball CPU Cooler
    ZALMAN 9500A 92mm 2 Ball CPU Cooler - Retail
    Item #: N82E16835118223
 -$15.00 Instant
    $63.99
    $48.99
Subtotal:  $914.37
Related Pr oduct
><))))º>
Profile: addict
More Information
You could build a pretty nice upgradeable C2D system for that.
>< ))))º>  >< ))))º>  >< ))))º>  >< ))))º>  >< ))))º>
Profile: nimble knuckle
More Information
Why would you get an Nvidia SLI board and use an ATI card? I prefer ATI, but if one buys an SLI board, and one can only afford a single graphics card, then buy Nvidia. That way, an extra card down the line provides SLI.
Cut corners, live off of Ramen noodles and peas (just joking), and get this board for Crossfire:
http://www.newegg.com/Product/Prod [...] 6813131224
Or get this card for SLI if the Nvidia board is a must:
http://www.newegg.com/Product/Prod [...] 6814125085
Crossfire scales better than SLI right now and the more expensive Crossfire board will support 4 3850's in the future, or two 3870's today. The SLI board is still good and the identically priced 8800GT 256 wins by a few fps in some games but loses by a few fps in others compared to the 3850. Both are midranged but the 8800GT only allows high settings with medium textures in many games (ie due to 256 memory limitations).
See the bar graphs at Anandtech:
http://www.anandtech.com/video/sho [...] i=3175&p=8
SLI and Crossfire are not interchangeable. There is, as of yet, no standard that would allow Crossfire on an SLI board or SLI on a Crossfire board. Intel using Crossfire instead of SLI might create a standard for the future, but that's a couple of years away at best.
I'd also get a better power supply. That will cost closer to $89 to $99. Get a combined amps on the 12 volt rail that your graphics card requires for SLI or Crossfire. Go for one by Cooler Master, Antec etc. Get one with an active PFC. Seasonic is the best, but they're a bit pricey.
I'm using an Antec Neo on one system and an Antec Earthwatts on another (550 and 500 watts). My older Nvidia 405 chipset board has a Coolermaster Realpower 450, but that only has 22 amps on the 12 volt rail, a bit low after a couple of years.
Your graphics card will have amps requirement for a single card and for SLI or Crossfire. Look at the card's specs to make sure you can match the amps you need on the power supply.
If he wants upgradeable AMD and better multicard performance, he should get an AMD chipset like the 790 Crossfire, preferably by ASUS. At least those are good to go for a future B3 stepping Phenom.
Heck, even an ASUS 690G motherboard's good for a Phenom. Too many AM2 boards aren't.
As for an affordable C2D system that's upgradeable, that too. Still, not everyone prefers Intel, and it's nice to have good AMD options.
Message edited by yipsl on 12-29-2007 at 04:53:23 AM
Resident Jerk
More Information
Heres a good overclocking system:
(My system build)
Antec 900
Gigabyte P35-DS3L
E2180 @ 3.0
2 Gigs Crucial Ballistix DDR2-800
8800GT or HD3870 and eventually Crossfire later on
Hard Drive: WD320AAKS
Optical: Samsung SH-203B
You can change things around based on deals that are going on.
With Vista 64-bit and a good PSU it was under $900
Message edited by Silverion7 7 on 12-29-2007 at 04:31:28 AM
99% of all computer problems are user related
Gigabyte P35-DS3L | E2180 @ 3.0
EVGA 8800GT SC | 2gb Crucial Ballistix 800
Profile: enthusiast
More Information
choose the path padwan : Crossfire or SLI
More Information
That's his big choice, at least both the ASUS 790 and the Nvidia 590 boards support Phenom for a future upgrade. I like ASUS, we have two M2A-VM 690G and an old P5RD-1 X200.
Much better than the old  MSI K9N6SGM-V Nvidia 405, that has the following limitation:
Quote :
One PCI Express X16 slot (Run at x8 mode)
   (Due to the specification of the chipset, ATI X8xx, X7xx, X5xx, and X3xx series graphic card will not be supported.)
http://www.msicomputer.com/product [...] V&class=mb
I'd contacted their tech support when I wanted to get an X1650 Pro for it, and they emailed me back saying to use an Nvidia card in that motherboard. So I went 7600GS instead.
Last Nvidia board I'll ever buy!
Message edited by yipsl on 12-29-2007 at 05:09:35 AM
Add a reply
Google Ads
