Alright i posted a thread a while ago about my Psu and now that i have checked the amps while underload (playing crysis dx10 on high) My amps total go to 23-25 and my psu has dual rails both combied at 29a.
So my questions is do i need a new one?
It gets hot and i can start to smell it.
And i was wondering if this would be a good solution
http://www.newegg.com/Product/Prod [...] 6817139003
My System is...
Intel core2duo e6750
4 gb Patriot ddr2 800 in sli mode
80 gb Hdd ide (planning on getting a sata)
Hd 3870
And the current psu im using
http://www.newegg.com/Product/Prod [...] 6817153052
Sponsored Links
If it gets hot and you can smell it, then yes it's time for a new one.
The VX450 provides more +12v power and has a higher efficiency rating than your current unit, go for it.
------------------------------ q9650 @ 4.050 | Asus Rampage Formula | 2x2 Corsair Dominators | WD Black 640 x2
EVGA GTX260 Core216 @ 686/1479/1103 | Antec TPN 750
Reply to Delluser1
cool the amps should be fine im guessing but will 450 watts be enough?
Reply to Fatality2
http://www.extreme.outervision.com [...] orlite.jsp
use this its a good approximate of how much wattage you need, and if your going to ad new hardware soon then be sure to ad that with the powersupply calculator so that the psu will last you a good amount of time even with some minor future upgrades, if its not enough wattage look at the 520hx its the next step up with a very high amount of 12v amps
Reply to monste4321
The amps are what matter, most of your system runs off the +12v rail.
From johnnyguru's review of the VX450
"Keeping in mind that this power supply is only a 450W and only has one PCI-e connector, I will say that this unit, rated at continuous, can certainly power any single GPU rig. The efficiency is good, the regulation good, the noise non-existent."
http://www.jonnyguru.com/modules.p [...] ry&reid=64
Reply to Delluser1
with 100 peak and 100 cpu it req 438 thats really close to 450
Reply to Fatality2
There's a VX550 too. That would give you more room to add disks or whatever.
Reply to aevm
My System is...
Hd 3870
The actual 12v amperage available on your current PSU is ~23.3. This is calculated by taking the 12v wattage(280) and dividing by 12v. I say ~23.3 as it is a lower quality PSU and therefore uses looser tolerance components than higher quality units.
The Corsair 450vx 33amp on the 12v. More than enough for a single card rig. The 550vx gives you even more headroom with 41 amps for a few bucks more if that is a concern.
I would definitely get a replacement before the TT fails and takes other components with it.
------------------------------ I know what I know, and I don't know what I don't know.
Reply to tlmck
That's a wattage recommendation for a quality psu that will run your machine, not actual power use.
Reply to Delluser1
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Power supply question
There are 1178 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
