I have (had actually) two RAID arrays on my machine. One was a RAID 1 system disk (C used for my apps and OS and was comprised of two 320Gb drives. The other was a RAID 0 for data (D and was comprised of two 500Gb drives.
We had a power cut (lasted about a minute) and when I turned my PC back on the BIOS seemd to have reset itself to default settings. Date and time etc. all were reset which was not a problem but so was the SATA setting reset back to IDE instead of Raid. If I change the SATA setting in the BIOS back to Raid the machine will not boot up.
If I leave the Raid settings in BIOS at IDE, Windows boots up and in Windows Explorer I now see two 320Gb drives (C: and E with exactly the same OS and Apps content so clearly the RAID 1 has just split into two disks and the content is good.
I also still see the D: drive in Windows Explorer but no files show up and under properties it shows 0 free space and 0 used space.
In the Intel Raid software utility I still can see the two Raid arrays as set up.
The mobo is an Asus P5K-E with intel chipset and I have used the onboard Raid controller.
Is there a way I can get the Raid arrays back without deleting all the data? Any Raid experts out there?
