Ok I have been pondering this upgrade for a few months now and was wondering am I going to notice a huge difference in speed,performance and visuals with an upgrade? I strictly do gaming and not much of anything else. I am not really into overclocking and just want something fast and stable.
Now all I was thinking about upgrading for now was my case,motherboard and cpu. I can use my ram,video card and PSU for now and upgrade the rest to this:
Antec 900
GIGABYTE GA-P35-DS3L
Intel Core 2 Duo E8400 Wolfdale 3.0GHz
In the future [maybe alot sooner] a HD3870 or HD3870X2
So will I notice a huge difference with this upgrade or just a little or no noticeable difference? My budget is $500 for Case/Motherboard/CPU....the video card upgrade will come later.
------------------------------MSI P965 Motherboard|Pentium D Dual core 3.2Ghz|2gb pc2 6400 800 ram|180gbMaxtor SATA HD| Visiontek HD3850 256mb|Westinghouse 22 inch widescreen lcd monitor
For many things, yes you will see a big difference. My wife has a similar CPU and I'm going to give her my e6750 when I get a quad. According to the CPU charts, she'll see quite a jump. You'll see an even bigger one for CPU-bound programs. Don't expect a big FPS jump in games; the HD3850 begins to be taxed at 1680x1050 (mine certainly is).
------------------------------There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
So would i be better off just upgrading my video card to a 3870,8800gt or 3870X2 instead of motherboard/cpu upgrade? What I am actually looking for is more fluid and better graphics for games like COD4 and WIC when running at 1680x1050 with everything maxed out.
Message edited by dallas0593 on 01-31-2008 at 05:31:16 PM
Reply to dallas0593
So i ask again, if i am purely looking to upgrade my gaming performance only I am better off just upgrading my video card then i am upgrading my cpu/motherboard?
Reply to dallas0593
Yes. Something like an 8800GT with 512MB of RAM would be a notable step up. I'm in a similar situation and may do the same. I've got a 3870 sitting on a shelf, but I'm not happy about the HD38xx drivers, particular relating to fan / cooling issues. It looks like I will be going back to nVidia, possibly the Asus model with a radial fan on it.
Reply to jtt283
Why not just d/l rivatuner and manually up your gpu fan speeds? I have read that this takes care of any cooling issues. The HD 3870 by Visiontek has been on my list for quite some time now and for $50 cheaper then any 8800gt 512md card you can't go wrong. Now the HD3870X2 is out I am really confused
I tried that. The results are not consistent. Typically only one or two of the threshholds I set actually change the fan speed. If it's the 40% and 80% ones (completely ignoring the one for 60%), the fan audibly revs up and down while I'm playing. I'm thinking of redoing it at a fixed 60% and see how that goes, but still the card and/or its drivers are buggy to behave this way. I found an article at guru3d about BIOS issues on that card, so...
Reply to jtt283
UPS will be dropping off my new $285 USD 8800GTS-512 (G92) withen the hour. Like haveing a 8800GTX but uses alot less power.
EDIT: UPS truck is here now!!
------------------------------*While we crash and burn, small, low tech, agrarian societies such as the Hmong in the mountains of Laos will continue on without so much as blinking an eye.*
Reply to ZOldDude
There is nothing wrong with the P965 Chipset so you should just get a Core 2 Duo E4600 , E6420, E6600, etc. whichever fits you budget and upgrade the video 8800 GT 512 or 8800 GTS 512 (Not the 640 or 320) or ATI 3870. Your ram etc. is good enough, I am running a 8800 GTS on 500 watts without problems. Your mobo limits you to 1066 FSB unless you can manually set it to 1333 which many but not all P965 Mobos allow this. If yours does then an E6750, E6850 will be a good upgrade. Any one of those Core 2 duos should be faster than anthing based on the P4, Mhz doesn't mean as much as it used to a 2.4 E4600 C2D or higher will out perform a P4 based processor of a higher clock easily in most cases.
Message edited by Evil-Weazel on 01-31-2008 at 08:31:29 PM
