This will be my very first build. I've been gaming for far too long with subpar systems and I decided it's time to build my own system. My budget is going to be around $1300 max. Since this is my first time building a system from the ground up, I just want to make sure I have everything I will need for the system to work properly. If there is anything that I have missed or compatibility issues please let me know. I do plan on making a slight attempt to overclock in the future once I'm a little more confident and have reasearched more, however, I don't plan on going SLI. ( That's for running two graphic cards if i'm not mistaken?)
When using the Antec Nine Hundred case, do I need to consider if the power cable from my PSU is long enough to connect to the mobo, since the Nine Hundred holds the PSU at the bottom?
I've only been able to locate OEM Hard drives, will I run into any complications with this seeing how it doesn't incude the wiring/manual and disk? If so, what will I need to purchase to complete the installation?
Also, I am really unclear on the OEM version of the Windows XP Home OS. From what I understand, you can only download this version once, if you try to upgrade/swap out your MOBO then you won't be able to use this copy. What if I have a faulty MOBO and have to order a new one, will I have to purchase another copy of Windows XP Home afterwards. How exactly does that work if someone could please enlighten me. As far as the OEM version, will it even be a good idea for a first time builder to use OEM or should I opt for the retail version. I would really like to avoid that if at all possible, the retail version puts me way over budget.
Here is what I am considering so far after alot of research. Thanks for any help in advance.
I'm not focusing on the hardware for this reply just the OS. (I'll leave the hardware for those more up to date).
I wouldn't suggest OEM versions of Windows.
It's just too much bother if you change hardware and have to keep contacting Microsoft to verify you are not a pirate or something.
I would suggest getting the full non oem version and you can install it if necessary each time you upgrade or rebuild your machine without too much hassle.
I still have the full XP with SP2 version and even once I had to contact Microsoft when I switched out a DVD drive and reconfigured/changed my network card to try to put some files on my linux machine. Windows saw the hardware change (network/DVD drive) and made life complicated. I can't imagine being any sort of enthusiast and only having an oem version.
Good Luck with your build.
Grant.
Message edited by a_dude on 12-30-2007 at 05:55:49 AM
I would get the GA-P35-DS3R motherboard, because it has more SATA ports and RAID and more cables (for your OEM drives) and a bit better audio. Ditch the Rosewill PCI card, plenty of USB 2.0 ports on the mobo already.
The DVD-ROM is probably pointless. If copying DVD to DVD it's safer to do it via hard disk anyway. Ditch it or make it a burner for $10 more.
"Onboard" means it's included in the motherboard - no separate card to buy or install.
If possible get a 22" monitor. It shouldn't be much more money than a 19", and the resolution is 1680x1050 instead of 1440x900. Your video card can handle that very well.
Edit: the monitor you picked costs $192 with shipping. If you can afford $230 instead, get this one:
Acer AL2216Wbd Black 22" 5ms DVI Widescreen LCD
http://www.newegg.com/Product/Prod [...] 6824009094 $38 more but you get higher resolution, better viewing angle, DVI connection (i.e. no digital to analog to digital conversions on the way to introduce noise), included DVI cable.
Even better, get a monitor locally so you can check it for dead pixels first.
Message edited by aevm on 12-30-2007 at 07:13:06 AM
Thanks for the suggestions so far everyone. I'll definitely look for a retail version of the Windows-xp OS. I had a bad feeling about that OEM version to begin with thanks for clarifying that a_dude.
nhobo, I don't think the case looks too bad personally, it has kind of grown on me and the pros seem to outweigh the looks. Unless of course you know of a prettier box with similar/great air flow, I'm definitely open to any suggestions. You'll have to forgive my ignorance but what would be the benefit of switching over to the 2x 160/250GB drives with 16MB caches - JBOD RAID? My knowledge is limited so far but I'm learning. Would I need to switch out the mobo to something capable of utilizing RAID like the one aevm mentioned? I honestly have no idea if the current one does. (I'm going to research more on that).
aevm, great suggestions, I dropped the DVD-ROM and the Rosewill PCI card, definitely helps with the overall cost since I need to look into a retail OS. I'm currently reading up on that GA-P35-DS3R motherboard you mentioned (possibly more questions concerning that to follow). That is a decent price on the 22" monitor. Although, I may have to wait for the new monitor, depending on the final build cost w/shipping.
JBOD = Just a Bunch Of Drives. Put you OS/applications on one and your data and Windoze paging file on the other. Almost as fast at RAID0 without any of the drawbacks. More drives = more speed, just don't RAID them. I like the Gigabyte Triton case, clean & simple look, lots of features, quiet, great cooling, less cost.
WOW, someone besides me likes the Triton cases. I've used this one the last two builds I've done and will use it for mine, unless I go with the Triton. Good luck
